rchrnsh Posted February 5, 2015 Posted February 5, 2015 Will AutoCAD Land Development Desktop 2009 install on a Windows 8.1 64 bit computer? Quote
ReMark Posted February 6, 2015 Posted February 6, 2015 Oh it should install alright the question is however will it run. There are always going to be problems running old software under mew operating systems. Your challenge will be troubleshooting your own problems because 1) you won't get any help from AutoDesk and 2) there aren't enough other users running the same combination of programs for you to get consistent and reliable help. Quote
rkmcswain Posted February 6, 2015 Posted February 6, 2015 I wouldn't bet on it running OK. You'll just have to try it, or stay on WinXP. Quote
ReMark Posted February 6, 2015 Posted February 6, 2015 Might be able to get it to run using a program called LongBow. Quote
BlackBox Posted February 6, 2015 Posted February 6, 2015 Will AutoCAD Land Development Desktop 2009 install on a Windows 8.1 64 bit computer? You don't happen to have a valid WinXP license, and running Win8.1 Pro/Enterprise are you? The only option I can even come up with, requires both - if so, then you can install that WinXP license on a Client Hyper-V Virtual Machine OOTB. Cheers Quote
