Enigmacy Posted February 6, 2015 Posted February 6, 2015 Hello guys, I'm new to autoCAD. I Know I look stupid asking this but anyways.. I used the divide function to divide two lines into 11 point each. I now need to draw lines from each of these point but I'm unable to click the point with the LINE Command. Need help TESIS ordeño.dwg Quote
Enigmacy Posted February 6, 2015 Author Posted February 6, 2015 Thank you sir, I just googled the snap Function and I was able to figure this out. Thank you so much, Kind regards! Quote
RobDraw Posted February 6, 2015 Posted February 6, 2015 You could also have the divide command insert blocks instead of points. If the lines are the same length, make a block with just the line in it and use the [block] option in divide. Quote
BIGAL Posted February 6, 2015 Posted February 6, 2015 Another is the Cal function you can nominate a distance Line 'Cal just trying to remember which function. Quote
