I got same problem with coordination. My code has error like this: "error: bad argument type: 2D/3D point:nil "
(defun dtr (a)
 (* pi (/ a 180.00))
(defun rtd (a)
 (/ (* a 180.00) pi)
(defun c:Dome ()
(setq osm (getvar "osmode"))
(setq dK (getdist   "\nDiameter of dome: "))
(setq hv (getreal   "\nHeight of dome: "))
(setq n (getint       "\nNumber of grid: "))
(setq p1 (getpoint "\nBase point: "))
(setq goc (/ 360 n))
(setq alpha (dtr  goc ))
;(setq beta  (dtr (- 180 goc)) )
(setq beta  (dtr  (/ (- 180 goc) 2) ))
(setvar "cmdecho" 1)
(setvar "osmode" 0)
(setq p2 ( polar p1 (* 0 pi)  dK) )
(setq pc (mid p1 p2))
(setq ra  (distance p1 pc))
(setq canh (* 2 ra  (sin (/ alpha 2) )) )
(setq p3  (polar p1 beta  canh ))
(setq  x1      (car pc)
      y1     (cadr pc)
      z1     (caddr pc) )
(setq  z2  (+ z1 hv))
(setq pdc (list  x1 y1 z2))
(command  "line" p1 p3 "" )
(setq s1 (entlast))
(command  "-array" s1  ""  "p" pc  n "" "" )
(command "_.ucs" "zaxis"  zo pdc)
(setq zo (trans zo 0 1))
(setq phi (/ 180 8 ))
(setq phi (dtr  phi ))
(setq canh2 (* 2 ra  (sin (/ phi 2) )) )
(setq r2 (/ (+ (* dk dk) (* 4 (* hv hv)) ) (* 8 hv)) ) ; ban kinh cua vom
(setq  zo  (- z2 r2))
(setq oc (list  x1 y1 zo))
(setq deta  (dtr  (/ (- 180 phi) 2) ))
(setq zeta  (angle p1 zo))
(setq zeta1 (abs (- deta zeta)))
(setq zd1   (*  r2 (sin zeta1) ))
(setq zeta2 (abs (- zeta1 phi)))
(setq zd2   (+ zd1 (*  r2 (sin (rtd zeta2)) )))
(setq zeta3  (abs (- zeta1 phi)))
(setq zd3   (+ zd2 (*  r2 (sin (rtd zeta3)) )))
(setq xd1 (*  r2 (cos (rtd zeta1)) ))
(setq xd2 (*  r2 (cos (rtd zeta2)) ))
(setq xd3 (*  r2 (cos (rtd zeta3)) ))
(setq pd2 (list  xd1 y1 zd1))
(setq pd3 (list  xd2 y1 zd2))
(setq pd4 (list  xd3 y1 zd3))
(command  "line" p1 pd2 "")
(setq s2 (entlast))
(command  "line" pd2 pd3 "")
(setq s3 (entlast))
(command  "line" pd3 pdc "")
(setq s4 (entlast))
(command  "-array"  s2  s3 s3 ""  "p" pc  n "" "" )
(command "_.ucs"  "p" )
(setvar "osmode" osm)
Edited by fuccaro
Adding the CODE tags
(defun dtr (a) (* pi (/ a 180.00)))
(defun rtd (a) (/ (* a 180.00) pi))
[color=magenta](defun mid (p1 p2)
(list (/ (+ (car p1) (car p2)) 2)(/ (+ (cadr p1) (cadr p2)) 2)(/ (+ (caddr p1) (caddr p2)) 2))
[/color]
(defun c:dome ()
(setq alpha (dtr goc))                           ;(setq beta (dtr (- 180 goc)) )
(setq beta (dtr (/ (- 180 goc) 2)))
(setvar "osmode" 0)
(setq p2 (polar p1 (* 0 pi) dK))
[b][color=magenta] (setq pc (mid p1 p2))[/color][/b]
(setq canh (* 2 ra (sin (/ alpha 2))))
(setq p3 (polar p1 beta canh))
(setq x1 (car pc)
      y1 (cadr pc)
      z1 (caddr pc)
(setq z2 (+ z1 hv))
(command "line" p1 p3 "")
(setq s1 (entlast))
(command "-array" s1 "" "p" pc n "" "")
[b][color=magenta]
(setq zo (trans zo 0 1));<-----
(command "_.ucs" "zaxis" zo pdc);<-----
[/color][/b]
(setq phi (/ 180 )
(setq phi (dtr phi))
(setq canh2 (* 2 ra (sin (/ phi 2))))
(setq r2 (/ (+ (* dk dk) (* 4 (* hv hv))) (* 8 hv))) ; ban kinh cua vom
(setq zo (- z2 r2))
(setq deta (dtr (/ (- 180 phi) 2)))
(setq zd1 (* r2 (sin zeta1)))
(setq zd2 (+ zd1 (* r2 (sin (rtd zeta2)))))
(setq zd3 (+ zd2 (* r2 (sin (rtd zeta3)))))
(setq xd1 (* r2 (cos (rtd zeta1))))
(setq xd2 (* r2 (cos (rtd zeta2))))
(setq xd3 (* r2 (cos (rtd zeta3))))
(setq s2 (entlast))
(setq s3 (entlast))
(setq s4 (entlast))
(command "-array" s2 s3 s3 "" "p" pc n "" "")
(command "_.ucs" "p")
Thanks. I have function for midpoint but i forgot. Thanks for yo' help. Let me test it.
After I run it. So it still has error about point. It just draw the boundary below don't draw the curve of dome
