Sengna Posted February 15, 2015 Share Posted February 15, 2015 Is it possible to change the multileader text from Lower case to upper case all at once? rather change one by one. Thanks Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 15, 2015 Share Posted February 15, 2015 Sounds like a lisp to me. The nearest alternative I can find is to select all of them, then open properties and click on the edit button in the text contents line. The Mtext editor will then cycle through all of them, but you will still have to highlight each text and change them manually. I was hoping matchprop would do it, but it does not. Quote Link to comment Share on other sites More sharing options...
Sengna Posted February 16, 2015 Author Share Posted February 16, 2015 Sounds like a lisp to me. The nearest alternative I can find is to select all of them, then open properties and click on the edit button in the text contents line. The Mtext editor will then cycle through all of them, but you will still have to highlight each text and change them manually. I was hoping matchprop would do it, but it does not. Yeah, i have to change one by one which was a pain, Match Prop won''t work for 2014 Autocad Version. I double click on the MLD text hightlight and right click--- Change case to UPPER. hope Lee mac can develope Lisp to help with this. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 16, 2015 Share Posted February 16, 2015 Yeah, i have to change one by one which was a pain, Match Prop won''t work for 2014 Autocad Version. I double click on the MLD text hightlight and right click--- Change case to UPPER. hope Lee mac can develope Lisp to help with this.Yeah, but if you do it my way for the time being, it will at least automatically open the mtext editor for you at each one. one would think AutoDesk would attach a case change macro or something to the contents box on the properties dialog. If they are all the same word, you can do it with Find/Replace all at once. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 16, 2015 Share Posted February 16, 2015 (edited) (strcase text) in lisp just need a few minutes to mod one Ok done now (defun caps ( / ss len x objtext) (vl-load-com) (setq ss (ssget "X" (list (cons 0 "Mtext,text")))) (setq x 0) (setq len (sslength ss)) (repeat len (setq ent (ssname ss x)) (setq objtext (vlax-ename->vla-object ent)) (vla-put-textstring objtext (strcase (vla-get-textstring objtext))) (setq x (+ x 1)) ) (caps) Edited February 17, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
Sengna Posted February 17, 2015 Author Share Posted February 17, 2015 (strcase text) in lisp just need a few minutes to mod one I have but a bit busy at moment. (defun caps ( / ss len x objtext) (vl-load-com) (setq ss (ssget "X" (list (cons 0 "Mtext,text")))) (setq x 0) (setq len (sslength ss)) (repeat len (setq ent (ssname ss x)) (setq objtext (vlax-ename->vla-object ent)) (vla-put-textstring objtext (strcase (vla-get-textstring objtext))) (setq x (+ x 1)) ) (caps) Should i just type these code to the command prompt Bigal??? or just strcase?? Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 17, 2015 Share Posted February 17, 2015 Should i just type these code to the command prompt Bigal??? or just strcase??Hang on, he's gotta modify this one a little. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 17, 2015 Share Posted February 17, 2015 Sorry thats the code copy it all to Notepad and save as a .lsp file use Appload to run. Post updated above Quote Link to comment Share on other sites More sharing options...
Sengna Posted February 17, 2015 Author Share Posted February 17, 2015 Sorry thats the code copy it all to Notepad and save as a .lsp file use Appload to run. Post updated above I know how to save these code on notepad but how do i upload it? do you have a screenshot.? thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 17, 2015 Share Posted February 17, 2015 I'm sure this has been covered before in one of your threads. Use the APPLOAD command to load the lisp routine into AutoCAD then type "caps" to start it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 18, 2015 Share Posted February 18, 2015 Segna 399 posts is it you or is someone else using your name ? Should know about appload. Quote Link to comment Share on other sites More sharing options...
