Frannym Posted February 16, 2015 Posted February 16, 2015 Hi All, I have a filing cabinet that is 1000mm and I need to change it to 800mm. No idea how to do this. Be really grateful for any info you can give me. Big thanks Franny Quote
Gotrekk Posted February 16, 2015 Posted February 16, 2015 Hi there, what about selecting it and scaling it to 0.8 ? Quote
ReMark Posted February 16, 2015 Posted February 16, 2015 Or if only one dimension is being changed (length or width) use the STRETCH command. Quote
BIGAL Posted February 17, 2015 Posted February 17, 2015 Select the two lines that make corner press F3 snap off make sure ortho on F8 drag via mouse red dot in direction required smaller or bigger ok enter 200 corner will move, repeat lower corner. Quote
