Visual Styles in drawing
Does anyone know if it's possible to apply the various visual styles for drawing views?
If by different visual styles you mean the options for Shaded, Hidden Line, and Hidden Line removed...then yes. On each view you want to change, Edit the View, then simply uncheck the box called Style from Base or Parent. Its a little check box that will allow you to change that view's style.
Welcome back Mark :D . As said above you can have full control over visual styles in the drawing views, every dia box has tools to play with:)
