Hi guys,
Just wondering how to control the vertical line spacing for the MTEXT created when using the TXT2MTXT Express Tool.
I have tried adjusting the TSPACEFAC system variable, and while that does have influence over the vertical line spacing for MTEXT created as MTEXT, it doesn't seem to impact the TXT2MTXT Express Tool.
Does anyone know of another way to set the vertical line spacing for converted MTEXT?
Thanks a lot for any help.
Have you tried to adjust the system variable TSPACETYPE?
You might get a result with that.
I no longer use the command TXT2MTXT, save something using right justify, close then reopen and you sould see why, in 2013.
I recommend Lee Mac's lsp. Text2MText Upgraded it might help with the problem you are having, get it here;
http://www.lee-mac.com/text2mtext.html
