yaim229 Posted February 20, 2015 Posted February 20, 2015 I have question, I have hardcopy paper, maybe 1:1 or 1:2 but that angle,width that anything no dimensions. I not understand how to draw correct dimension that. is it possible scan that paper, save to TIFF, and use CAD to open that TIFF file (background). and I try draw that line again. from that Image background. any idea please! Quote
BIGAL Posted February 20, 2015 Posted February 20, 2015 You have answered your own question save to jpg maybe rescale image to a known value and trace over correcting as you go. Quote
yaim229 Posted February 20, 2015 Author Posted February 20, 2015 thanks, but my cad program not found that Import>Image that function. I am used that 3rd cad program. is it "Autodesk" special function? also if "Autodesk", which version is it support or need LT or 3D? Quote
ReMark Posted February 20, 2015 Posted February 20, 2015 Are you saying there is no IMAGEATTACH command in the version of AutoCAD that you are using? Quote
yaim229 Posted February 20, 2015 Author Posted February 20, 2015 thanks, imageattach is my need command, i'm sorry I not clear my question. also, if future I want to delete that image. simple type "erase" completed. am i correct? Quote
ReMark Posted February 20, 2015 Posted February 20, 2015 Yes, the image can be erased just like any other object. Quote
yaim229 Posted February 20, 2015 Author Posted February 20, 2015 BTW, how to known that import image is 1:1 size? and if re-draw, that lines, normal I need what Technology? Quote
ReMark Posted February 20, 2015 Posted February 20, 2015 There is no guarantee the image will come in at 1:1 scale. You would have to scale it based upon some reference. Once the image is scaled then draw over the top of it using normal lines, arc, polylines, etc. What is the image of that you are attaching? Quote
yaim229 Posted February 20, 2015 Author Posted February 20, 2015 thanks, in this moment, no any image need redraw that lines. but If known how to perfect redraw that lines) that technology, is not bad. cad program very powerful, but, basic level, I know how to draw that lines,arc,maybe enough. Quote
ReMark Posted February 20, 2015 Posted February 20, 2015 In other words you are not doing this at the moment and your question was merely for informational purposes. I see. OK. Quote
