Beeftimer Posted February 25, 2015 Posted February 25, 2015 So this is very odd. I am going through a process to clean up some .dwg files to save them as .dxf. One of the goals is to reduce the size of the files to Don't ask me how I stumbled across this... phenomena, but when I download the original .dwg file to my computer, it will have a file size of, say, 2.9Mb. If I open the file in AutoCAD and do nothing but ctrl+S and close the file, the file size is now 1.4Mb. Can anyone explain this? It seems like a good thing at first glance, but anything that is unexplained, IMO, is a potential problem. It seems I'm getting something for nothing. I'm very perplexed. Beef Quote
ReMark Posted February 25, 2015 Posted February 25, 2015 What version of AutoCAD was used to create the drawings originally? Quote
Beeftimer Posted February 25, 2015 Author Posted February 25, 2015 (edited) When I open in AutoCAD (I'm using 2013), it says "Opening an AutoCAD 2013 format file." So I'm assuming it's 2013. Notepad tells me "AC1027." Not sure if this is the original version or the version used when last saved, but regardless, to me it shouldn't make a difference. **EDIT Shouldn't make a difference between original being something and last saved being something else. I assume the last saved would be what is important, e.g. if it was originally created in 2013, last saved in 2000 and then I'm trying to open it in 2013, I imagine that might make a difference. Not saying that what you are asking shouldn't make a difference, ReMark. I just want to clarify that. I think it was a good question. Edited February 25, 2015 by Beeftimer Quote
nestly Posted February 25, 2015 Posted February 25, 2015 SAVEFIDELITY and LARGEOBJECTSUPPORT are both variables that can affect the filesize, although I doubt the latter would apply based on the size of your drawings. Also, are you getting any warnings when opening the file, such as missing fonts or shp files? Quote
Beeftimer Posted February 25, 2015 Author Posted February 25, 2015 SAVEFIDELITY and LARGEOBJECTSUPPORT are both variables that can affect the filesize, although I doubt the latter would apply based on the size of your drawings. Also, are you getting any warnings when opening the file, such as missing fonts or shp files? No warnings. This is exactly what is displayed when the file is opened: Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: AUTODESKSEEK Customization file loaded successfully. Customization Group: MODELDOC Customization file loaded successfully. Customization Group: CONTENTEXPLORER Customization file loaded successfully. Customization Group: ACFUSION Customization file loaded successfully. Customization Group: EXPRESS Opening an AutoCAD 2013 format file. Regenerating layout. Regenerating model. Command: Command: AutoCAD menu utilities loaded. Command: COMMANDLINE Command: Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application. Command: Nothing more, nothing less. I tried opening the original file and changing the values of both LARGEOBJECTSUPPORT and SAVEFIDELITY and, although they effected the resulting file size slightly, the file was still much smaller after saving than the original file size. Changing those values affected the file size by only about 100kb. Any other ideas? Quote
nestly Posted February 25, 2015 Posted February 25, 2015 IMO, you should just knock on wood and be thankful the drawings are getting smaller and not larger. Do you know what version they were previously saved with? Sometime in the last 20 years, AutoCAD changed the default Polyline type and made conversion to the new pline type automatic, but that's not to say a previous used didn't change the variable, so perhaps you're silently and transparently converting all the plines to the newer/more efficient type when the drawing is opened. Admittedly.. it's a long shot. Care to attach one of the drawings prior to the filesize reduction? Quote
Beeftimer Posted February 25, 2015 Author Posted February 25, 2015 IMO, you should just knock on wood and be thankful the drawings are getting smaller and not larger. Do you know what version they were previously saved with? Sometime in the last 20 years, AutoCAD changed the default Polyline type and made conversion to the new pline type automatic, but that's not to say a previous used didn't change the variable, so perhaps you're silently and transparently converting all the plines to the newer/more efficient type when the drawing is opened. Admittedly.. it's a long shot. Care to attach one of the drawings prior to the filesize reduction? Haha! Yes, knock on wood, indeed. I don't know of any way to check and see which version it was originally drawn on, but you're probably right. Seems like it would be the only thing that would make sense. I would attach one of the drawings, but I don't know if my company would frown on that or not. I'd better be safe than sorry. It's not that big of a deal since, as you said, they're getting smaller and not larger. As long as it doesn't cause any problems it's really more a matter of my own curiosity anyway. Thanks for your replies. Now I'm going to try and beat the snow home. Beef Quote
Dana W Posted February 25, 2015 Posted February 25, 2015 At some point AutoDesk also added automatic functions to unbloat scalelists, and DGN linetypes. Quote
ROBP Posted February 25, 2015 Posted February 25, 2015 FYI Version Internal version AutoCAD versions DWG R1.0 MC0.0 AutoCAD Release 1.0 DWG R1.2 AC1.2 AutoCAD Release 1.2 DWG R1.40 AC1.40 AutoCAD Release 1.40 DWG R2.05 AC1.50 AutoCAD Release 2.05 DWG R2.10 AC2.10 AutoCAD Release 2.10 DWG R2.21 AC2.21 AutoCAD Release 2.21 DWG R2.22 AC1001, AC2.22 AutoCAD Release 2.22 DWG R2.50 AC1002 AutoCAD Release 2.50 DWG R2.60 AC1003 AutoCAD Release 2.60 DWG R9 AC1004 AutoCAD Release 9 DWG R10 AC1006 AutoCAD Release 10 DWG R11/12 AC1009 AutoCAD Release 11, AutoCAD Release 12 DWG R13 AC1012 AutoCAD Release 13 DWG R14 AC1014 AutoCAD Release 14 DWG 2000 AC1015 AutoCAD 2000, AutoCAD 2000i, AutoCAD 2002 DWG 2004 AC1018 AutoCAD 2004, AutoCAD 2005, AutoCAD 2006 DWG 2007 AC1021 AutoCAD 2007, AutoCAD 2008, AutoCAD 2009 DWG 2010 AC1024 AutoCAD 2010, AutoCAD 2011, AutoCAD 2012 DWG 2013 AC1027 AutoCAD 2013, AutoCAD 2014, AutoCAD 2015 Quote
