"Mitch" Posted December 16, 2008 Posted December 16, 2008 Hellllllp!!! I'm supposed to be able to do two different white sheet page setups in paper space and switch between each setups without having to move my drawing into the printable area. But the white sheet moves more than 3 feet between each setup!! And these are scaled drawings. Can I get the sheet to more or less stay in one place, so I can switch between each setup and print? Or is there an internal setting I need to know? One setup is for publishing to Acrobat and the other is to a network printer in the office. Quote
cpriedel Posted December 16, 2008 Posted December 16, 2008 Use the Page setup manager (right click on your Lauot tab) and modify the layout. I always use EXTENTS in the plot area, but i seen others use LAYOUT. Dont forget to center Plot. Let me know if that helped any. Quote
