joao56777 Posted March 3, 2015 Posted March 3, 2015 Hi, How can i do the weld in the object attached. first, i try to do this object, with the insert frame, but then i cant do the weld in the pipe. But, then i thought that will be another way. And i did the object with the surfaces and offsets. Could you help me? Best regards TE.ipt Quote
ROBP Posted March 3, 2015 Posted March 3, 2015 Hi, How can i do the weld in the object attached. first, i try to do this object, with the insert frame, but then i cant do the weld in the pipe. But, then i thought that will be another way. And i did the object with the surfaces and offsets. Could you help me? Best regards Just print as pdf with adding weld sign with weld full penetration and 30deg. bevel preparation on both neck and main pipe and send it in the shop welders will do the rest hth Quote
joao56777 Posted March 4, 2015 Author Posted March 4, 2015 Just print as pdf with adding weld sign with weld full penetration and 30deg. bevel preparation on both neck and main pipe and send it in the shop welders will do the rest hth Hi, What i want is to weld the two pipes of fitting (intersection between the horizontal and vertical) in inventor. Inventor coudnt let me do the preparation and wel, or just welding. How did you weld a tee fitting like this. I try to do a chanfer but gave me an error... Do you understand? Quote
ecshclark Posted March 4, 2015 Posted March 4, 2015 Weldments are done in Assembly. Create an assembly, insert your objects (make two pipe parts), constraint, then convert to weldment. Go to Environments in the Assembly menu, then select Convert To Weldment... Quote
JD Mather Posted March 4, 2015 Posted March 4, 2015 Have you installed all Service Packs and Updates for your version of Inventor? (Hint: The correct answer is - No.) You have one part (you did not even do as multi-body solid). Where in the real world would you create this as one part (rather than an assembly of two parts) and if you could create as one part - why would you need to weld it? Quote
joao56777 Posted March 4, 2015 Author Posted March 4, 2015 Have you installed all Service Packs and Updates for your version of Inventor? (Hint: The correct answer is - No.) You have one part (you did not even do as multi-body solid). Where in the real world would you create this as one part (rather than an assembly of two parts) and if you could create as one part - why would you need to weld it? i'm not expert in inventor or autocad, and i have so much doubts. I need to put wel in the interception of this pipes, for annotation thar this weld was tested by x-ray. If you could help me, explain me how to do. Quote
