Need to download Autocad Civil 3D Users Guide 2013, cannot find PDF
Its not a pdf I think its a html file got to http://www.autodesk.com else its buried pretty deep in your C:\program search for acad.html
What happens when you type HELP.
Thank you very much. Let me clarify. I need a standalone PDF manual of the user manual. The help menu in AutoCAD goes to their help website. Unfortunately, each item is a separate website with links. I cannot print individual chapters as if I were printing a PDF.
Thanks!
Pretty sure you can opt to use the one on your hard drive instead of the online version, that's how mine is set up, not sure if that helps you, but maybe you can make a PDF from that one.
Should be where BIGAL suggested, mine are at C:\Program Files\Autodesk\AutoCAD 2011\Help\. If there are any PDFs of the Help file, someone made them from those files.
Version 2013 C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Help\index.html
Clicking print only allows for printing of current page the pdf by others has probably used some program to join all the html pages.
