happyunited Posted December 17, 2008 Posted December 17, 2008 I have a drawing that I received and it seems to have lots and lots of lines on top or each other. I have attached a small sample of it and i'm trying to delete all the unecessary lines etc. Is OVERKILL the correct command as it doesn't seem to work?? Cheers Drawing2.dwg Quote
ReMark Posted December 17, 2008 Posted December 17, 2008 And you know it isn't working because.........? Overkill it again. Quote
happyunited Posted December 17, 2008 Author Posted December 17, 2008 And you know it isn't working because.........? Overkill it again. I know it isn't working because the lines are still there!! Should I untick all the boxes? Quote
Tiger Posted December 17, 2008 Posted December 17, 2008 I got no solution, but I can confirm that it's not working... this is what I get on the command line: Command: overkill Select objects: Specify opposite corner: 50 found Select objects: 65 duplicate(s) deleted. 5 object(s) deleted. Invalid option keyword. and when I do ctrl+A again, it's the same amount of lines..... Quote
Tiger Posted December 17, 2008 Posted December 17, 2008 When I exploded it all (except the text) - then Overkill worked. Quote
happyunited Posted December 17, 2008 Author Posted December 17, 2008 PEDITACCEPT had to be set to 0, now it works fine. Quote
ReMark Posted December 17, 2008 Posted December 17, 2008 Life is so much easier when OPs answer their own question. Thanks for the update. Quote
Tiger Posted December 17, 2008 Posted December 17, 2008 very nice, and kudos to Happy for coming back and telling us the solution, no need to bang head against this one anymore Quote
