SuperNim143 Posted March 12, 2015 Posted March 12, 2015 I am developing an application that automatically generates a set of drawings from a template using user input and an access dbase. As a part of this I have code that is called to update a single block attribute. It works great for the blocks that are in model space! My issue is with Paperspace. Instead of updating the existing attribute it adds a new attribute with the same name. How do I access the Paperspace block attributes?!? The code used for this is below. Private Sub UpdateBlockAttribute(acBlkRef As BlockReference, attTag As String, textValue As String, Optional modelSpace As Boolean = True) Dim acBlkTable As BlockTable Dim acBlkDef As BlockTableRecord Dim acCurLyr As ObjectId Dim acAttRef As DatabaseServices.AttributeReference = Nothing Dim attFound As Boolean = False Try acBlkTable = acTrans.GetObject(acdb.BlockTableId, OpenMode.ForRead) acBlkDef = DirectCast(acBlkTable(acBlkRef.Name).GetObject(OpenMode.ForRead), BlockTableRecord) Dim acLyrTbl As LayerTable = acTrans.GetObject(acdb.LayerTableId, OpenMode.ForRead) acCurLyr = acdb.Clayer If acLyrTbl.Has("0") Then acdb.Clayer = acLyrTbl("0") End If For Each acEntId In acBlkDef Dim acEnt As Entity = acTrans.GetObject(acEntId, OpenMode.ForRead) If Not IsNothing(acEnt) Then If acEnt.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.AttributeDefinition" Then Dim acAttDef As AttributeDefinition = DirectCast(acEnt, AttributeDefinition) If Not IsNothing(acAttDef) And Not acAttDef.Constant Then acAttRef = New AttributeReference acAttRef.SetAttributeFromBlock(acAttDef, DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).BlockTransform) If acAttDef.Tag.ToString = attTag Or acAttRef.Tag.ToString = attTag Then attFound = True Exit For End If End If End If End If Next DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).AttributeCollection.AppendAttribute(acAttRef) 'IF THE ATTRIBUTE DOES NOT EXIST, ADD A NEW ONE... If Not attFound Then acAttRef.Tag = attTag acAttRef.Justify = AttachmentPoint.MiddleCenter acTrans.AddNewlyCreatedDBObject(acAttRef, True) acAttRef.UpgradeOpen() End If acAttRef.TextString = textValue acAttRef.DowngradeOpen() acdb.Clayer = acCurLyr Catch ex As Exception MsgBox("Update Block Attribute: " & ex.Message) End Try End Sub Quote
BlackBox Posted March 12, 2015 Posted March 12, 2015 I am developing an application that automatically generates a set of drawings from a template using user input and an access dbase. As a part of this I have code that is called to update a single block attribute. It works great for the blocks that are in model space! My issue is with Paperspace. Instead of updating the existing attribute it adds a new attribute with the same name. How do I access the Paperspace block attributes?!? The code used for this is below. Private Sub UpdateBlockAttribute(acBlkRef As BlockReference, attTag As String, textValue As String, Optional modelSpace As Boolean = True) Dim acBlkTable As BlockTable Dim acBlkDef As BlockTableRecord Dim acCurLyr As ObjectId Dim acAttRef As DatabaseServices.AttributeReference = Nothing Dim attFound As Boolean = False Try acBlkTable = acTrans.GetObject(acdb.BlockTableId, OpenMode.ForRead) acBlkDef = DirectCast(acBlkTable(acBlkRef.Name).GetObject(OpenMode.ForRead), BlockTableRecord) Dim acLyrTbl As LayerTable = acTrans.GetObject(acdb.LayerTableId, OpenMode.ForRead) acCurLyr = acdb.Clayer If acLyrTbl.Has("0") Then acdb.Clayer = acLyrTbl("0") End If For Each acEntId In acBlkDef Dim acEnt As Entity = acTrans.GetObject(acEntId, OpenMode.ForRead) If Not IsNothing(acEnt) Then If acEnt.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.AttributeDefinition" Then Dim acAttDef As AttributeDefinition = DirectCast(acEnt, AttributeDefinition) If Not IsNothing(acAttDef) And Not acAttDef.Constant Then acAttRef = New AttributeReference acAttRef.SetAttributeFromBlock(acAttDef, DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).BlockTransform) If acAttDef.Tag.ToString = attTag Or acAttRef.Tag.ToString = attTag Then attFound = True Exit For End If End If End If End If Next DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).AttributeCollection.AppendAttribute(acAttRef) 'IF THE ATTRIBUTE DOES NOT EXIST, ADD A NEW ONE... If Not attFound Then acAttRef.Tag = attTag acAttRef.Justify = AttachmentPoint.MiddleCenter acTrans.AddNewlyCreatedDBObject(acAttRef, True) acAttRef.UpgradeOpen() End If acAttRef.TextString = textValue acAttRef.DowngradeOpen() acdb.Clayer = acCurLyr Catch ex As Exception MsgBox("Update Block Attribute: " & ex.Message) End Try End Sub Welcome to CADTutor. You haven't posted complete code, or a sample drawing, so it will be hard for me (or others) to pinpoint the exact issue you're facing. That said, this may be of some help: using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using acApp = Autodesk.AutoCAD.ApplicationServices.Application; namespace BlackBox.AutoCAD.Samples { class FOO { private DocumentCollection acDocs = acApp.DocumentManager; void UpdateBlockAttributes(string blockName, string tagString, string textString) { Document doc = acDocs.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; tagString = tagString.ToUpper(); // set clayer to "0" layer acApp.SetSystemVariable("clayer", "0"); using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction()) { // get the blocktable BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); // instead of iterating the entire blocktable, check to see if // the target block exists within this database's blocktable if (!bt.Has(blockName)) { // if not, then notify user, and exit // uncomment the notification, if you feel it useful - I tend // to not call writemessage() within non-commandmethod methods //ed.WriteMessage("\nerror; Block \"{0}\" does not exist ", blockName); return; } // otherwise, open the blocktablerecord BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[blockName], OpenMode.ForRead); // and instead, simply iterate all inserts of the target blocktablerecord foreach (ObjectId id in btr.GetBlockReferenceIds(true, false)) { BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForRead); // <-- check for locked layer here? // check for attributes foreach (ObjectId attId in br.AttributeCollection) { AttributeReference ar = tr.GetObject(attId, OpenMode.ForRead) as AttributeReference; if (ar != null && ar.Tag.ToUpper() == tagString) { ar.UpgradeOpen(); ar.TextString = textString; ar.DowngradeOpen(); } } } tr.Commit(); } } } } Cheers Quote
BIGAL Posted March 13, 2015 Posted March 13, 2015 I am not a .NET person but as the OP wants paperspace wouldn't you need to check the block location and make sure its paperspace plus on the correct layout tab. In lisp (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 tabname)))) in 99.9% for me this returns only 1 block which is the title block but could return more. Quote
BlackBox Posted March 13, 2015 Posted March 13, 2015 I am not a .NET person but as the OP wants paperspace wouldn't you need to check the block location and make sure its paperspace plus on the correct layout tab. In lisp (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 tabname)))) in 99.9% for me this returns only 1 block which is the title block but could return more. I understood the OP to seeking to modify many if not all BlockReferences (by blockName), but was only successful with those located in ModelSpace. Perhaps the OP can clarify shortly. Cheers Quote
SuperNim143 Posted March 13, 2015 Author Posted March 13, 2015 Thanks for your responses. I am calling this routine to populate an individual attribute on a single instance of the block. It works great for everything in model space. The blocks that I have trouble with are a titleblock and an additional description block that is contained on Layout1 in paperspace. Instead of updating the existing attribute, it adds a brand new one with the same name. I am using the same Function and Sub for both model and paperspace. First I call a function that retrieves the block reference. (TBClean is the blockname in this case) acBlkRef = InsertBlockReference("TBClean", False, New Point3d(-0.5, 0.5, 0), True, "TITLE", Colors.Color.FromColorIndex(Colors.ColorMethod.ByAci, 0)) 'black Then I call the sub to update the attribute. (DESCRIPTION(CONT) is the attribute.) UpdateBlockAttribute(acBlkRef, "DESCRIPTION(CONT)", strDesc) Below is the code for the Function and Sub Private Function InsertBlockReference(blockName As String, modelSpace As Boolean, insPt As Point3d, updateExisting As Boolean, Optional layerName As String = "", Optional layerColor As Colors.Color = Nothing) As BlockReference Dim acBlkTable As BlockTable Dim acLyrTbl As LayerTable Dim acCurLyrID As ObjectId Dim acBlkRef As BlockReference = Nothing Dim acSpaceID As ObjectId Dim acBlkTableRecord As BlockTableRecord Dim acBlkTableRecordID As ObjectId Dim acNewLyr As New LayerTableRecord Try acBlkTable = acTrans.GetObject(acdb.BlockTableId, OpenMode.ForRead) If IsNothing(acBlkTable) Then 'InsertBlockReference = Nothing Return Nothing End If 'store current layer to make it current again after function acLyrTbl = acTrans.GetObject(acdb.LayerTableId, OpenMode.ForRead) acCurLyrID = acdb.Clayer 'if a layer is specified, set it to the current layer If layerName <> "" Then If acLyrTbl.Has(layerName) Then acdb.Clayer = acLyrTbl(layerName) Else acNewLyr.Name = layerName acNewLyr.Color = layerColor acLyrTbl.UpgradeOpen() acLyrTbl.Add(acNewLyr) acLyrTbl.DowngradeOpen() acTrans.AddNewlyCreatedDBObject(acNewLyr, True) acdb.Clayer = acLyrTbl(layerName) End If End If 'check to see if the block is already in the CAD file If acBlkTable.Has(blockName) And updateExisting Then 'get the BlockReference for the block acBlkTableRecord = DirectCast(acTrans.GetObject(acBlkTable.Item(blockName), OpenMode.ForRead), BlockTableRecord) Dim acObjIdColl As ObjectIdCollection = acBlkTableRecord.GetBlockReferenceIds(True, True) Dim acEntId As ObjectId For Each acEntId In acObjIdColl 'acBlkRef = acEntId.GetObject(OpenMode.ForRead) acBlkRef = TryCast(acEntId.GetObject(OpenMode.ForWrite), BlockReference) Next Else 'if the block is NOT in the CAD file, insert it from the dwg file If IO.File.Exists(Me.txtCADBlocksPath.Text & "\" & blockName & ".dwg") Then Dim acBlkSourceDb As Database acBlkSourceDb = New Database(False, True) acBlkSourceDb.ReadDwgFile(Me.txtCADBlocksPath.Text & "\" & blockName & ".dwg", FileOpenMode.OpenForReadAndAllShare, True, Nothing) acBlkTableRecordID = acdb.Insert(blockName, acBlkSourceDb, True) 'insert the new block acBlkRef = New BlockReference(insPt, acBlkTableRecordID) 'select the correct block table record to insert the new block into... ModelSpace or PaperSpace If modelSpace = True Then acSpaceID = acBlkTable(BlockTableRecord.ModelSpace) Else acSpaceID = acBlkTable(BlockTableRecord.PaperSpace) End If acBlkTableRecord = DirectCast(acTrans.GetObject(acSpaceID, OpenMode.ForWrite), BlockTableRecord) acBlkTableRecord.AppendEntity(acBlkRef) acTrans.AddNewlyCreatedDBObject(acBlkRef, True) Else MsgBox("InsertBlock: Block """ & blockName & """ DWG not found") Return Nothing End If End If Catch ex As Exception MsgBox("InsertBlock: " & ex.Message) Finally acdb.Clayer = acCurLyrID End Try Return acBlkRef End Function Private Sub UpdateBlockAttribute(acBlkRef As BlockReference, attTag As String, textValue As String, Optional modelSpace As Boolean = True) Dim acBlkTable As BlockTable Dim acBlkDef As BlockTableRecord Dim acCurLyr As ObjectId Dim acAttRef As DatabaseServices.AttributeReference = Nothing Dim attFound As Boolean = False Try acBlkTable = acTrans.GetObject(acdb.BlockTableId, OpenMode.ForRead) 'acBlkDef = DirectCast(acBlkTable(acBlkRef.Name).GetObject(OpenMode.ForRead), BlockTableRecord) Dim acLyrTbl As LayerTable = acTrans.GetObject(acdb.LayerTableId, OpenMode.ForRead) acCurLyr = acdb.Clayer If acLyrTbl.Has("0") Then acdb.Clayer = acLyrTbl("0") End If If acBlkTable.Has(acBlkRef.Name) Then acBlkDef = acTrans.GetObject(acBlkRef.Id, OpenMode.ForRead) End If For Each acEntId In acBlkDef Dim acEnt As Entity = acTrans.GetObject(acEntId, OpenMode.ForRead) If Not IsNothing(acEnt) Then If acEnt.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.AttributeDefinition" Then Dim acAttDef As AttributeDefinition = DirectCast(acEnt, AttributeDefinition) If Not IsNothing(acAttDef) And Not acAttDef.Constant Then acAttRef = New AttributeReference acAttRef.SetAttributeFromBlock(acAttDef, DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).BlockTransform) If acAttDef.Tag.ToString = attTag Or acAttRef.Tag.ToString = attTag Then attFound = True Exit For End If End If End If End If Next DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).AttributeCollection.AppendAttribute(acAttRef) 'IF THE ATTRIBUTE DOES NOT EXIST, ADD A NEW ONE... If Not attFound Then acAttRef.Tag = attTag acAttRef.Justify = AttachmentPoint.MiddleCenter acTrans.AddNewlyCreatedDBObject(acAttRef, True) acAttRef.UpgradeOpen() End If acAttRef.TextString = textValue acAttRef.DowngradeOpen() acBlkDef.SynchronizeAttributes() acdb.Clayer = acCurLyr Catch ex As Exception MsgBox("Update Block Attribute: " & ex.Message) End Try End Sub I hope all of that makes sense. I will have to clear some confidential data from the drawings before they could be posted, but I can do that if you still need them. Quote
BlackBox Posted March 14, 2015 Posted March 14, 2015 Thanks for clarifying. So forgive my asking, as there must be a reason that I am overlooking, but if you're programmatically inserting the BlockReference and then modifying said BlockReference's Attributes, why not just manually save a copy of the corrected block and insert/overwrite the BlockTableRecord? You could even first iterate the existing INSERTS as I show above, storing values, and properties as needed before hand, post-populating said values in resultant blocks as needed. Cheers Quote
BlackBox Posted March 14, 2015 Posted March 14, 2015 Consider: var btr = <BlockTable>["<BlockName>"].GetObject(<OpenMode>); Quote
SuperNim143 Posted March 26, 2015 Author Posted March 26, 2015 Sorry I did not respond. I have been tied up out of the office for a while. This program is going to be used by our drafters. The idea is that it will be fairly dynamic. They will be able to place their block (using the appropriate block name and attribute names) in a folder and point the program to that location. This will allow them to make the block appearance fit with the customer. The program will update that block for them based on their selections. Looking for the attributes presence in the block and adding it if does not exist will ensure that all required fields are present in the block. We are trying to steer the drafting leads in a more robust direction, but currently this is what they want. The last bit of code that you sent, would that address the paperspace attribute issue? From what I can tell my issue is not opening or reading the paperspace blocks, but locating the attributes. For some reason when it compares the .tag to attTag it never finds a match, even if it DOES exist. And this is only on the paper space. That's what I don't understand. Is the issue possibly that I am not directing it to a particular layout? I am going to take a closer look at the code you provided now that I am back in the office. Thanks again for your input. Quote
BlackBox Posted March 27, 2015 Posted March 27, 2015 Sorry I did not respond. I have been tied up out of the office for a while. This program is going to be used by our drafters. The idea is that it will be fairly dynamic. They will be able to place their block (using the appropriate block name and attribute names) in a folder and point the program to that location. This will allow them to make the block appearance fit with the customer. The program will update that block for them based on their selections. Looking for the attributes presence in the block and adding it if does not exist will ensure that all required fields are present in the block. We are trying to steer the drafting leads in a more robust direction, but currently this is what they want. The last bit of code that you sent, would that address the paperspace attribute issue? From what I can tell my issue is not opening or reading the paperspace blocks, but locating the attributes. For some reason when it compares the .tag to attTag it never finds a match, even if it DOES exist. And this is only on the paper space. That's what I don't understand. Is the issue possibly that I am not directing it to a particular layout? I am going to take a closer look at the code you provided now that I am back in the office. Thanks again for your input. No worries; I am working all too many hours myself lately, and it doesn't appear to be letting up anytime soon. In any event, perhaps it would be prudent to post a sample drawing, that you can reproduce this issue in, that way we're not having to setup a sample data set & code, etc. from scratch in order to try and help? Cheers Quote
SuperNim143 Posted March 27, 2015 Author Posted March 27, 2015 terminal_template_WIPED.dwg A wiped version of the template dwg is attached. In this case I am updating the DESCRIPTION(CONT) attribute on the TBCLEAN title block in paperspace. Like I said it doesn't find the existing attribute so it then creates a new one with the same name and updates that value. After some more research I'm wondering if the issue stems from not selecting the layout tab. I started to try and bring that into the mix but I haven't had success yet. See my updated code for the Sub below. I feel like I am missing a step though. I get a response that it is not set to an instance of the object. (for all attributes) Private Sub UpdateBlockAttribute(acBlkRef As BlockReference, attTag As String, textValue As String, Optional modelSpace As Boolean = True) Dim acBlkTable As BlockTable = Nothing Dim acBlkDef As BlockTableRecord Dim acCurLyr As ObjectId Dim acAttRef As DatabaseServices.AttributeReference = Nothing Dim attFound As Boolean = False Dim acSpaceID As ObjectId Try acBlkTable = acTrans.GetObject(acdb.BlockTableId, OpenMode.ForRead) If modelSpace = False Then acSpaceID = acBlkTable(BlockTableRecord.PaperSpace) Else acSpaceID = acBlkTable(BlockTableRecord.ModelSpace) End If acBlkDef = DirectCast(acTrans.GetObject(acSpaceID, OpenMode.ForRead), BlockTableRecord) 'acBlkDef = DirectCast(acBlkTable(acBlkRef.Name).GetObject(OpenMode.ForRead), BlockTableRecord) Dim acLyrTbl As LayerTable = acTrans.GetObject(acdb.LayerTableId, OpenMode.ForRead) acCurLyr = acdb.Clayer If acLyrTbl.Has("0") Then acdb.Clayer = acLyrTbl("0") End If For Each acEntId In acBlkDef Dim acEnt As Entity = acTrans.GetObject(acEntId, OpenMode.ForRead) If Not IsNothing(acEnt) Then If acEnt.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.AttributeDefinition" Then Dim acAttDef As AttributeDefinition = DirectCast(acEnt, AttributeDefinition) If Not IsNothing(acAttDef) And Not acAttDef.Constant Then acAttRef = New AttributeReference acAttRef.SetAttributeFromBlock(acAttDef, DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).BlockTransform) If acAttDef.Tag.ToString = attTag Or acAttRef.Tag.ToString = attTag Then attFound = True Exit For End If End If End If End If Next DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).AttributeCollection.AppendAttribute(acAttRef) 'IF THE ATTRIBUTE DOES NOT EXIST, ADD A NEW ONE... If Not attFound Then acAttRef.Tag = attTag acAttRef.Justify = AttachmentPoint.MiddleCenter acTrans.AddNewlyCreatedDBObject(acAttRef, True) acAttRef.UpgradeOpen() End If acAttRef.TextString = textValue acAttRef.DowngradeOpen() acBlkDef.SynchronizeAttributes() acdb.Clayer = acCurLyr Catch ex As Exception MsgBox("Update Block Attribute: " & ex.Message & acAttRef.BlockName.ToString & " - " & acAttRef.Tag.ToString) End Try End Sub Quote
BlackBox Posted March 27, 2015 Posted March 27, 2015 Thanks for posting the drawing so quickly, and for the additional information. I'll see what I can find out as soon as I can - I am in the middle of completing someone else's project at the moment (why you'd wait to the end of a submittal, to do the vertical Profiles, sanitary runs, revise the storm [if at all], and design the vertical for water & force mains is beyond me, but that's what I've been called in to do, dah dah dah dahhhh. Grrr). Also, what version(s) are you planning to support? Cheers Quote
SuperNim143 Posted March 27, 2015 Author Posted March 27, 2015 AutoCad 2013 and.net framework 4 Quote
SuperNim143 Posted March 27, 2015 Author Posted March 27, 2015 I feel like I'm close, but something is still missing. I have made a modification to factor layout into it. I have been able to confirm that it is now iterating through the correct block and does pull in that attribute, however, it still does not recognize the tag as equal to the attTag that is passed in. I'm attaching a quick screen shot of the issue I have with my output. If you look at the attribute names you can see that it creates a new attribute with an identical name. Private Sub UpdateBlockAttribute(acBlkRef As BlockReference, attTag As String, textValue As String, Optional modelSpace As Boolean = True) Dim acBlkTable As BlockTable = Nothing Dim acBlkDef As BlockTableRecord = Nothing Dim acCurLyr As ObjectId Dim acAttRef As DatabaseServices.AttributeReference = Nothing Dim attFound As Boolean = False Dim acSpaceID As ObjectId Dim layoutDict As DBDictionary Dim dictEntry As DictionaryEntry Dim layout As Layout Dim layoutID As ObjectId Try layoutDict = acTrans.GetObject(acdb.LayoutDictionaryId, OpenMode.ForRead, False) 'If modelSpace = False Then 'acSpaceID = acBlkTable(BlockTableRecord.PaperSpace) 'Else 'acSpaceID = acBlkTable(BlockTableRecord.ModelSpace) ' End If ' acBlkDef = DirectCast(acTrans.GetObject(acSpaceID, OpenMode.ForRead), BlockTableRecord) If (layoutDict <> Nothing) Then For Each dictEntry In layoutDict layoutID = dictEntry.Value layout = acTrans.GetObject(layoutID, OpenMode.ForRead) acBlkTable = acTrans.GetObject(acdb.BlockTableId, OpenMode.ForRead) acBlkDef = DirectCast(acBlkTable(acBlkRef.Name).GetObject(OpenMode.ForRead), BlockTableRecord) Dim acLyrTbl As LayerTable = acTrans.GetObject(acdb.LayerTableId, OpenMode.ForRead) acCurLyr = acdb.Clayer If acLyrTbl.Has("0") Then acdb.Clayer = acLyrTbl("0") End If For Each acEntId In acBlkDef Dim acEnt As Entity = acTrans.GetObject(acEntId, OpenMode.ForRead) If Not IsNothing(acEnt) Then If acEnt.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.AttributeDefinition" Then Dim acAttDef As AttributeDefinition = DirectCast(acEnt, AttributeDefinition) If Not IsNothing(acAttDef) And Not acAttDef.Constant Then acAttRef = New AttributeReference acAttRef.SetAttributeFromBlock(acAttDef, DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).BlockTransform) If acAttDef.Tag.ToString = attTag Or acAttRef.Tag.ToString = attTag.ToString Then attFound = True Exit For End If End If End If End If Next If attFound = True Then Exit For End If Next End If DirectCast(acTrans.GetObject(acBlkRef.ObjectId, OpenMode.ForRead), BlockReference).AttributeCollection.AppendAttribute(acAttRef) 'IF THE ATTRIBUTE DOES NOT EXIST, ADD A NEW ONE... If Not attFound Then acAttRef.Tag = attTag acAttRef.Justify = AttachmentPoint.MiddleCenter acTrans.AddNewlyCreatedDBObject(acAttRef, True) acAttRef.UpgradeOpen() End If acAttRef.TextString = textValue acAttRef.DowngradeOpen() 'acBlkDef.SynchronizeAttributes() acdb.Clayer = acCurLyr Catch ex As Exception MsgBox("Update Block Attribute: " & ex.Message & acAttRef.BlockName.ToString & " - " & acAttRef.Tag.ToString) End Try End Sub paperspace blocks.docx Quote
Roberto casado Posted May 2, 2022 Posted May 2, 2022 Hi, i try to edit the attributes in a Block reference, but i think your program work goog, but never change my private attributes. You know why? Quote
