OMEGA-ThundeR Posted March 12, 2015 Posted March 12, 2015 Hello, I'm rather new in AutoCAD 3D. For the first time now i'm trying to fix an design in an image. http://s14.postimg.org/f5ak8j5tt/example.png / http://postimg.org/image/yn57oh2rh/27b06f5f/ As you can see in the image the design doen't line up with the side of the road. Is there a way to correct this within the 'perspective orbit' ( I use the 3D orbit mode and right click my mouse to swtich to perspective mode) Is there a way to shift it's focus point? Quote
Cad64 Posted March 28, 2015 Posted March 28, 2015 Not sure if you've figured this out yet or not, but while you're in 3DOrbit mode with "Projection" set to perspective, open your Properties palette and adjust the "Lens Length (mm)" until your model starts to match up with the photo. Quote
