Hi
Can somebody help me this Lisp file. It almost works and can I have the 2 functions in the one file? ("Center" & "Phantom")
;Create Center line;
(defun C:tozacentre ()
(tozacentre)
(setq oldlay (getvar "clayer"))
(setvar "clayer" "Centre")
(command "_line")
(while (= (getvar "cmdactive") 1 ) (command pause)
(setvar "clayer" oldlay)
;Create Pahntom line;
(defun C:tozaphantom ()
(tozaphantom)
(setvar "clayer" "Phantom")
(command "_line")
Try:
(defun C:tozacentre (/ oldlay)
 (command "_line")
 (while (= (getvar "cmdactive") 1 ) (command pause))
(defun C:tozaphantom (/ oldlay)
 (command "_line")
Hi Tombu
Thanks for that I have it working now and would like to ask you if you can help again
;;;;;;;;;;;;;;;;Create Centre line;;;;;;;;;;;;;;;;;
                   (/ oldline)
 (setq oldline (getvar "linetype"))
 (setvar "clayer" "Lines")
 (setvar "linetype" "CENTERTOZA")
 (command "_line")
 (setvar "linetype" oldline)
;End of file
I'm trying to get my different linetypes all on the same layer but having a different linrtype. I've done this wrong and hoping you can see away. Thanks again
1. Look at the defun function
2. You needed an *ERROR* function in case someone hits Esc or enters anoher command.
3. CeLtype is the system variable for current entity linetype.
4. This thread should have been in the AutoLISP, Visual LISP & DCL forum!
(defun C:tozacentre (/ *ERROR* oldlay oldline)
(defun *ERROR* (s)                    ; If an error (such as CTRL-C) occurs
                                     ; while this command is active...
 (if (/= s "Function cancelled")
   (princ (strcat "\nError: " s))
 (setvar "clayer" oldlay)		; current layer
 (setvar "celtype" oldline)	; current entity linetype
 (setq oldline (getvar "celtype"))
 (setvar "celtype" "HIDDEN2")
 (command "_line")
Hope that gets you started. Lisp can be really helpful.
Saw your other thread and modified the lisp to be able to create whatever using whatever layer, linetype, and lineweight you want.
Added *error* function in case user hits Esc or enters another command, also took in account layer and linetype may not be in the drawing yet.
(defun tozacentre (clayer celtype celweight command / *ERROR* filedia oldlay oldline)
 (setvar "filedia" filedia)			; display dialog box?
 (setvar "celweight" oldlwght)	; current entity linetype in hundredths of millimeters
 (setq filedia (getvar "filedia"))
 (setvar "filedia" 0)
 (command "-LAYER" "Make" clayer "")	; sets current layer, makes it if nessisary
 (or(tblsearch "ltype" "HIDDEN2")(command "-LINETYPE" "Load" "HIDDEN2" "" ""))
 ; add linetype if needed, still only works if linetype definition is in lin file.
 (setq oldlwght (getvar "celweight"))
 (setvar "clayer" clayer)
 (setvar "celtype" celtype)
 (setvar "celweight" celweight)
 (command "_line")
Celweight stores current entity linetype in hundredths of millimeters so putting:
(tozacentre "Lines" "CENTERTOZA" 9 "Line")
in a macro draws Lines on Layer Lines with linetype CENTERTOZA and lineweight 0.09
Tombu
Thank you very much for the help you have given me. I really appreciate it. I have used what you have helped me with and came up with a very productive solution. I have a template (dwt) I use for all my work which contains a "Lines" & "Construction" layer and the necessary line types. The following code now works perfectly. This takes care of all the line types I use in my daily drafting. Thanks again.
;;;;;;;;;;;;Create Construction line;;;;;;;;;;;;;;;
(defun C:tozaconstruction (/ oldlay)
 (setvar "clayer" "Construction")
 (command "_line")
(defun C:tozacenter (/ *ERROR* oldlay oldline)
(defun *ERROR* (s)
 (setvar "celtype" "CENTERTOZA")
 (command "_line")
;;;;;;;;;;;;;;;;Create Hidden line;;;;;;;;;;;;;;;;;
(defun C:tozahidden (/ *ERROR* oldlay oldline)
(defun *ERROR* (s)
 (setvar "celtype" "HIDDEN")
 (command "_line")
;;;;;;;;;;;;;;;;Create Hidden2 line;;;;;;;;;;;;;;;;
(defun C:tozahidden2 (/ *ERROR* oldlay oldline)
(defun *ERROR* (s)
 (command "_line")
;;;;;;;;;;;;;;;;Create Phantom line;;;;;;;;;;;;;;;;
(defun C:tozaphantom (/ *ERROR* oldlay oldline)
(defun *ERROR* (s)
 (setvar "celtype" "PHANTOMTOZA")
 (command "_line")
;;;;;;;;;Create Continuous .18 line;;;;;;;;;;;;;;;;
(defun C:18grey (/ *ERROR* oldlay oldcolor)
(defun *ERROR* (s)
 (setvar "celtype" oldcolor)
 (setq oldcolor (getvar "cecolor"))
 (setvar "cecolor" "08")
 (command "_line")
;;;;;;;;;Create Continuous .25 line;;;;;;;;;;;;;;;;
(defun C:25white (/ *ERROR* oldlay oldcolor)
(defun *ERROR* (s)
 (setvar "cecolor" "07")
 (command "_line")
;;;;;;;;;Create Continuous .35 line;;;;;;;;;;;;;;;;
(defun C:35yellow (/ *ERROR* oldlay oldcolor)
(defun *ERROR* (s)
 (setvar "cecolor" "02")
 (command "_line")
;;;;;;;;;Create Continuous .50 line;;;;;;;;;;;;;;;;
(defun C:50red (/ *ERROR* oldlay oldcolor)
(defun *ERROR* (s)
 (setvar "cecolor" "01")
 (command "_line")
;;;;;;;;;Create Continuous .70 line;;;;;;;;;;;;;;;;
(defun C:70cyan (/ *ERROR* oldlay oldcolor)
(defun *ERROR* (s)
 (setvar "cecolor" "04")
 (command "_line")
If you are using a template why didn't you include the linetypes in the template itself thus negating the need for using a custom lisp routine to load the linetypes in the first place?
Thanks ReMark for your comments. I was using that method but there are too many layers and I have to revert back to a particular layer each time after the line command. It's the way my software works. I use Autodesk Advance Steel and it needs to remain in the "Standard" layer for some functions to work correctly. So this lisp allows me to draw different lines and then change back to "Standard: layer.
Hi Tombu
After I draw a line and want to finish I need to press the right mouse button to end and the layer changes back to "oldlay" but if I press escape when I finish the line the routine ends and the layer doesn't revert back. Do you know if it is possible to have the option to either use escape or right mouse to end?
Regards
tony
