Or, using Entmod:
(defun c:lay (/ ent Nme obj)
 (vl-load-com)
 (while (setq ent (car (entsel "\nSelect Object on Layer: ")))
   (setq Nme (cdr (assoc 8 (entget ent))) obj (tblobjname "LAYER" Nme))
   (if (= 14 (strlen Nme))
       (entmod
         (subst
           (cons 2 (strcat Nme "_EX"))
             (assoc 2 (entget obj)) (entget obj)))
   (princ (strcat "\n<< Layer: " Nme " is not Standard Format >>"))))
 (princ))
  • Replies 105
  • Lee Mac
    41
  • alanjt
    30
  • JeepMaster
    15
  • kalarpu
    11
Blimey, this is an old thread... brings back some memories - I've come a long way since then!
Try this:
(defun c:lay (/ ent Nme)
 (vl-load-com)
   (setq Nme (cdr (assoc 8 (entget ent))))
     (vla-put-Name
       (vla-item
         (vla-get-Layers
           (vla-get-ActiveDocument
             (vlax-get-acad-object))) Nme)
       (strcat Nme "_EX"))
 (princ))
keep beating me to the punch. i clicked reply, then got up for a second, came back and finished my post and you beat me in.
this was a while ago.
Hi
Thanks you for answering.
I have some more question please.
-Only
-If the selected obj layer >14, just copy 14 only and create new layer and then add _E and then also change colour to "4"
-If 14_E is the existing layer, just changed the selected obj (which have first 14 exactly same to Existing 14 of 14_E ) to the existing layer
-Can be select multi objs
Thanks guys
Kalarpu
  1. The message can easily be changed.
  2. This can also be achieved.
  3. Not sure I understand what you mean by this one.
  4. Perhaps...
Perhaps something like this?
(defun c:lay (/ suff i ss ent Nme Obj nNme)
 (vl-load-com)
 (setq suff "_EX")   ;; Layer Suffix
 (setq lay (vla-get-Layers
               (vlax-get-acad-object))))
 (if (setq i -1 ss (ssget "_:L"))
   (while (setq ent (ssname ss (setq i (1+ i))))
           Obj (vlax-ename->vla-object ent))
     (cond ((= 14 (strlen Nme))
            (if (tblsearch "LAYER" (setq nNme (strcat Nme suff)))
              (vla-put-layer Obj nNme)
              (vla-put-Name (vla-item lay Nme) nNme)))
           ((< 14 (strlen Nme))
            (setq nNme (strcat (substr Nme 1 14) suff))
            (if (tblsearch "LAYER" nNme)
                (vla-put-color (vla-add lay nNme) acCyan)
                (vla-put-Layer Obj nNme))))
           (t (princ
                (strcat "\n** Layer: " Nme " is not a Standard Format"))))))
 (princ))
nice lee, i still think it should filter based on prefix. if it's a layering standard, it will begin with the same stuff. just for that 'one time' when a crazy layer exists with 14 characters, but doesn't follow layer standards.
(and (= (strlen "LAYERNAME") 14)
    (wcmatch "LAYERNAME" "[AECMV ]-*")
the second portion of this (what i posted earlier) will take care of that.
 (vl-load-com)
           (t (princ
 (princ))
Hi Lee and Alan
Thanks a lot
Sorry for my poor ENGLISH
You did what I want.
Thanks again
Kalarpu
Hi Lee and Alan
Thanks a lot
Thanks again
Kalarpu
No worries. I'm American, mine is not much better.
funny, i never capitalize for sentence structure when posting.
Hi Lee and Alan
Thanks a lot
Thanks again
Kalarpu
Not a problem - we managed to understand OK :)
Hi
I don't know how to combine Alan one to Lee one
Please help me
Thanks
Kalarpu
Just replace
(= 14 (strlen Nme))
With Alan's code.
You may also want to do the same with the (
(and (or (= (strlen Nme) 14)
        (wcmatch Nme "*_EX")
    (wcmatch Nme "[AECMV ]-*")
this might cover it a little better. that way, it won't throw a fit if it sees a layer with the "_EX" already. or am i not thinking propertly and just being redundant?
My routine does check for the layer already existing and puts the object on that layer if it does.
But that is assuming that the layer is not 14 chrs WITH the _EX on the end...
nelson_ha_ha.jpga%3E
ah hah!:geek:
I saw your Nelson :P
it worked?!
it worked?!
I saw the jumbled code and curiosity got the better of me o:)
;This program is produced by LEE MAC and edited by Alanjt for Kalarpu
;STANDARD LAYERS
(defun c:layO (/ suff i ss ent Nme Obj nNme)
(vl-load-com)
(setq suff "") ;; Layer Suffix
(cond ((and (= 14 (strlen Nme))(wcmatch Nme "[ACELMNS ]-*"))
((and(
(vla-put-color (vla-add lay nNme) acwhite)
(t (princ
(princ))
;EXISTING/APPROVED TO BE REMAIN
(defun c:layE (/ suff i ss ent Nme Obj nNme)
(vl-load-com)
(setq suff "_E") ;; Layer Suffix
((and(
(t (princ
(princ))
;PROPOSED NEW WORKS
(defun c:layN (/ suff i ss ent Nme Obj nNme)
(vl-load-com)
(setq suff "_N") ;; Layer Suffix
((and(
(vla-put-color (vla-add lay nNme) acMagenta)
(t (princ
(princ))
;EXISTING/APPROVED TO BE DEMOLISHED
(defun c:layR (/ suff i ss ent Nme Obj nNme)
(vl-load-com)
(setq suff "_R") ;; Layer Suffix
((and(
(vla-put-color (vla-add lay nNme) acyellow)
(t (princ
(princ))
Hi
My intension is to use in amendment or A&A projects.
One problem for me
Let say I have 3 objs in A-_MISC----_E- (Standard Layer) and then I want to change one obj to A-_MISC----_E-_N but when I select even one obj the whole standard layer(ALl 3 objs) change to new layer.
Actually I still want to keep the other two in standard layer.
Please help.
Thanks a lot
Kalarpu
