so, you want one that moves selected objects to a cloned layer suffixed with "_N", or are you wanting the written routine modified to do this?
  • Replies 105
  • Lee Mac
    41
  • alanjt
    30
  • JeepMaster
    15
  • kalarpu
    11
Please modify
Thanks
Kalarpu
Kalarpu - there is no need for three copies of the same LISP, with the only difference being the suffix - just make one sub-function, with the suffix as the argument and call it as needed. :wink:
I have no idea because I am just start learning.
Please guide me
Thanks
Please guide me
Thanks
Not a problem,
I meant like this:
 ;This program is produced by LEE MAC and edited by Alanjt for Kalarpu
(defun lays  (suff / i ss ent Nme Obj nNme)
 (vl-load-com)
 (setq lay (vla-get-Layers
             (vla-get-ActiveDocument
               (vlax-get-acad-object))))
 (if (setq i  -1 ss (ssget "_:L"))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (setq Nme (cdr (assoc 8 (entget ent)))
           Obj (vlax-ename->vla-object ent))
     (cond ((and (= 14 (strlen Nme)) (wcmatch Nme "[ACELMNS ]-*"))
            (if (tblsearch "LAYER" (setq nNme (strcat Nme suff)))
              (vla-put-layer Obj nNme)
              (vla-put-Name (vla-item lay Nme) nNme)))
           ((and (< 14 (strlen Nme)) (wcmatch Nme "[ACELMNS ]-*"))
            (setq nNme (strcat (substr Nme 1 14) suff))
            (if (tblsearch "LAYER" nNme)
                (vla-put-color (vla-add lay nNme) acwhite)
                (vla-put-Layer Obj nNme))))
           (t
            (princ
              (strcat "\n** Layer: " Nme " is not a Standard Format"))))))
 (princ))
(defun c:layO ( )
 (lays "")
 (princ))
(defun c:layE ( )
 (lays "_E")
 (princ))
(defun c:layN ( )
 (lays "_N")
 (princ))
(defun c:layR ( )
 (lays "_R")
 (princ))
I have made the suffix an argument and have called the sub-function "lays" each time.
Lee
Hi Lee Mac
Please check this "(setq nNme (strcat Nme suff))"
Because I think it changed(renamed) my standard layer to 14_N or 14_E or 14_R even I selected only one obj (the rest I still want to remain in standard layer).
I prefer to create newlayer base on standard not for just rename.
Thanks for your help
At the moment the LISP is checking to see if "14_E" exists, and, if it does it will move the object to it, else it will rename the layer to "14_E", are you saying that instead of renaming, to create a new layer and move the object to this new layer?
Yes, please create new layer instead of renaming because I just want to move the selected obj only to new layer so that other objs still remain in old layer
Thanks
How about this:
 (vl-load-com)
                (vla-add lay nNme)
           (t
            (princ
 (princ))
(defun c:layO ( )
 (lays "")
 (princ))
(defun c:layE ( )
 (lays "_E")
 (princ))
(defun c:layN ( )
 (lays "_N")
 (princ))
(defun c:layR ( )
 (lays "_R")
 (princ))
  • 4 weeks later...
Hi
When I use refedit in place, all layer changed to $-$14 and cannot use lisp already.Please help
  • 2 weeks later...
Is it possible to modify the lisp that you guys have here so that all the layers on the drawing will have "-DD" added on the end? It seems very close to be able to do it, but I can't figure it out.:(
ie: E-POWR-TEXT to E-POWR-TEXT-DD
The lazy man's way:
(defun c:laysuff (/ suff doc)
 (vl-load-com)
 (while (not (and (setq suff (getstring "\nSpecify Suff for all Layers: "))
                  (snvalid suff)))
   (princ "\n** Invalid Suffix **"))
 (vla-StartUndoMark (setq doc (vla-get-ActiveDocument
 (vlax-for lay (vla-get-layers doc)
    (vl-catch-all-apply 'vla-put-Name
      (list lay (strcat (vla-get-Name lay) suff))))
 (vla-EndUndoMark doc)
 (princ))
It works perfectly. Thanks LeeMac for your help as usual.:thumbsup:
How hard is it to remove suffix? so instead of vla-put-name, vla-remove-name? Sorry I don't know any VLA commands.
Haha, no such function I am afraid... we have to approach things differently :)
(defun c:RemSuff (/ suff doc)
 (vl-load-com)
 (while (not (and (setq suff (getstring "\nSpecify Suff to Remove: "))
                  (snvalid suff)))
      (list lay (vl-string-right-trim suff (vla-get-Name lay)))))
 (princ))
You could do something like this and it wouldn't add the suffix if said suffix already existed. (ie: Lay would become Lay-DD, but Fun-DD would be left as is)
 (vl-load-com)
                  (snvalid suff)))
   (or (wcmatch (strcase (vla-get-name lay)) (strcase (strcat "*" suff)))
      (list lay (strcat (vla-get-Name lay) suff)))))
 (princ))
Nice idea Alan - hadn't thought of it... but then I did say "lazy man's way"... o:)
Wow, LeeMac that is awsome stuff. Thanks for the super quick response.
I'm running into a little problem. If only some of my layers have the suffix I wish to remove, it doesn't seem to work.
ie: I have many layers with -NEWW and -EXST. And I want to remove all the -EXST from those layers.
Maybe it needs to have a search function to replace those layers only.:?
 (vl-load-com)
                  (snvalid suff)))
 (princ))
Thanks Alan. I didn't pick that one up untill I recheck all my layers. Thanks so much.
