It should remove it if the suffix is there - only drawback is if you have it duplicated, i.e.
(vl-string-right-trim "Mac" "LeeMacMac")
"Lee"
But it seems to remove it fine for me :) It is case-sensitive though o:)
  • Replies 105
  • Lee Mac
    41
  • alanjt
    30
  • JeepMaster
    15
  • kalarpu
    11
Nice idea Alan - hadn't thought of it... but then I did say "lazy man's way"... o:)
His question about removing a suffix made me think of it. Seemed a pretty good method to me, minus the while. :)
True - I wanted to filter bad characters, but the snvalid means that no spaces can be used - perhaps take out the while.
I just don't like that the user is forced to hit escape. I'd just rather use and and if the user types in crap, it just exits.
(defun c:laysuff (/ suff doc)
 (vl-load-com)
 (cond
   ((and (setq suff (getstring "\nSpecify Suffix for all layers: "))
         (snvalid suff)
    ) ;_ and
    (vla-StartUndoMark
      (setq doc (vla-get-ActiveDocument
                  (vlax-get-acad-object)
                ) ;_ vla-get-ActiveDocument
      ) ;_ setq
    ) ;_ vla-StartUndoMark
    (vlax-for lay (vla-get-layers doc)
      (or (wcmatch (strcase (vla-get-name lay)) (strcase (strcat "*" suff)))
          (vl-catch-all-apply
            'vla-put-Name
            (list lay (strcat (vla-get-Name lay) suff))
          ) ;_ vl-catch-all-apply
      ) ;_ or
    ) ;_ vlax-for
    (vla-EndUndoMark doc)
 ) ;_ cond
) ;_ defun
I think my problem is when the character is "-". So if I want to remove "-EXST" it doesn't work, but it works if I remove "EXST". Then my layers will be like this "E-TEXT-" :(
Ok, I've been doing some testing and result is very weird. Let say layers are as follows:
"Layer1"
"Layer11"
"Layer111"
Then I add suffix "-1" to all of them. It works fine.
"Layer1-1"
"Layer11-1"
"Layer111-1"
Now if I try to remove the suffix "-1" and the result is this:
"Layer"
"Layer11-1"
"Layer111-1"
It removed the "1-1" from the first layer and ignored the other two layers.:huh: I have no idea what's going on. Does this happen to you guys???
"Layer1"
"Layer11"
"Layer111"
"Layer1-1"
"Layer11-1"
"Layer111-1"
"Layer"
"Layer11-1"
"Layer111-1"
Yeah, I just noticed the same thing. I tried to remove "-TEXT" on several layers and it worked, but it also removed the T from layers that just ended in T.
What about something like this?
(defun c:RemSuff (/ suff doc name)
 (vl-load-com)
 (while (not (and (setq suff (getstring "\nSpecify Suff to Remove: "))
                  (snvalid suff)
             ) ;_ and
        ) ;_ not
   (princ "\n** Invalid Suffix **")
 ) ;_ while
 (vla-StartUndoMark
   ) ;_ setq
   (if (wcmatch (strcase (setq name (vla-get-name lay)))
       ) ;_ wcmatch
     (vl-catch-all-apply
       'vla-put-Name
       (list lay
             (substr name
                     1
                     (vl-string-position (ascii suff) name nil T)
             ) ;_ substr
       ) ;_ list
   ) ;_ if
 ) ;_ vlax-for
) ;_ defun
I'm still getting the same problem...Actually not quite the same. You did solve my Layer1-1 problem I showed earlier. But it doesn't remove others like when I have mix of "-DEMO" "-NEWW" layers
Really?
I added a suffix of "-DEMO" to all the layers, then was able to remove it from all layers. What are you getting when you try that?
Oh...sorry, it's my mistake. I tried to test it with our company's standard layers, which have a mix of all the layers we use. When I tried to remove "-DEMO" from layer "E-TEXT-DEMO" It didn't work because layer "E-TEXT" already exist.:oops: So I tried it on blank dwg and everything works like it's suppose to. Thanks. Alan for the help.:shock:
That makes sense. I'm sure that's the main reason Lee put a vl-catch-all-apply on the rename portion.
Thanks Alan - I didn't think vl-string-right-trim was the best way to do it - very unpredictable.
Yeah... that and I'm too lazy to check all the other things that would cause an error o:)
It's generally the best option. Why waste checks with tblsearch, etc. when the catch will take care of everything. I would have done the same thing.
Thanks for all the help Alan and Lee. You guys are great. I'm happy now.:D
No sweat. :)
We don't have anything better to do than rag on each others code. :twisted:
No sweat. :)
hehe true o:)
LoL:geek:...
Just noticed your links to your programs in the sig.... seems like everyone followed me on that one :wink: Buzzard, Freerefill... now you...
