The attached drawings has blocks with attributes, need to export those to excel as per the attached screen shot.
These are irrigation valve tags, in a drawing there will 100's of those tags
This will be helpful in scheduling irrigation
Valve tag.dwg
doesn't AutoCAD's native DATAEXTRACTION tool do this for you?
sir,
I have to select certain blocks out of a group and export, this for scheduling purpose
And this i need to do a lot of times, may 5 to 8 times a minute
So lisp programs are easier option
Hi Lee
The code works great, is possible to have some refinement
Code should export only the selected block & it should be capable of multiple selection.
Thanks in advance
Do you want the program to make you coffee too? :lol: ;)
Lee iam no that good with lisp programming:(
sir,
5 to 8 times a minute omg no time to draw or change nothing at that rate.
Automatic lisp to run in the background while drafting, lisp with a time laps or a time schedule quite a task i am anxious to see such coding.
R
