vanowm Posted March 23, 2015 Posted March 23, 2015 Hello. Some entities have duplicate item association in it's list (sorry don't know the proper term). i.e. a ruled surface is: ((-1 . <Entity name: 4008eaa0>) (0 . "POLYLINE") (330 . <Entity name: 4008ccd0>) (5 . "E7A4") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "MESH") (100 . "AcDbPolygonMesh") (66 . 1) (10 0.0 0.0 0.0) (70 . 16) ... ) [0] (-1 . <Entity name: 4008eaa0>) [1] (0 . "POLYLINE") [2] (330 . <Entity name: 4008ccd0>) [3] (5 . "E7A4") [4] ([color=red][b]100[/b][/color] . "AcDbEntity") [5] (67 . 0) [6] (410 . "Model") [7] (8 . "MESH") [8] ([color=red][b]100[/b][/color] . "AcDbPolygonMesh") [9] (66 . 1) [10] (10 0.0 0.0 0.0) [11] (70 . 16) [12] (40 . 0.0) [13] (41 . 0.0) [14] (210 0.0 0.0 1.0) [15] (71 . 2) [16] (72 . 13) [17] (73 . 0) [18] (74 . 0) [19] (75 . 0) Using assoc command returns only the first found association item. i.e. (print (assoc 100 (ENTGET (CAR (ENTSEL))))) Would return ([color=red][b]100[/b][/color] . "AcDbEntity") but not ([color=red][b]100[/b][/color] . "AcDbPolygonMesh") Two questions: 1) Is there a command that would return a list of all matched associations or we we have to go through entire list and search each item individually? 2) is there a way filter entities by such duplicate associations in (ssget), i.e. this doesn't work: (SSGET '((100 . "AcDbPolygonMesh"))) It allows select anything instead of only surfaces/meshes. Thank you. Quote
hanhphuc Posted March 23, 2015 Posted March 23, 2015 hi have a look dxf reference here (ssget'((0 . "POLYLINE")(70 . [color="red"]16[/color]))) Quote
Lee Mac Posted March 23, 2015 Posted March 23, 2015 1) Is there a command that would return a list of all matched associations or we we have to go through entire list and search each item individually? Consider a 'massoc' function to retrieve all items with a given key in an association list. 2) is there a way filter entities by such duplicate associations in (ssget), i.e. this doesn't work: (SSGET '((100 . "AcDbPolygonMesh"))) It allows select anything instead of only surfaces/meshes. hi have a look dxf reference here (ssget'((0 . "POLYLINE")(70 . [color="red"]16[/color]))) A good suggestion, however, since DXF group 70 is bit-coded, I would suggest using a Bitwise Masked Equals operator (reference), e.g.: (ssget '((0 . "POLYLINE") (-4 . "&=") (70 . 16))) Quote
hanhphuc Posted March 23, 2015 Posted March 23, 2015 Consider a 'massoc' function to retrieve all items with a given key in an association list. A good suggestion, however, since DXF group 70 is bit-coded, I would suggest using a Bitwise Masked Equals operator (reference), e.g.: (ssget '((0 . "POLYLINE") (-4 . "&=") (70 . 16))) Thank you Lee for the bonus guide! Noted! Quote
