Sandervp Posted March 24, 2015 Posted March 24, 2015 (edited) Problem command for creating dimension style I've got a command, beneath a toolbar button, which shall create several dimensional styles for different scales. If I have got a drawing with different dimensional styles, and none of these has got the same name as any dimensional style my command shall create, nothing is wrong. But if there is 1 existing style with the same name as one dimensional style my command shall create, it goes wrong. My command creates the following dimensional styles: Scale_1-10 scale_1-20 scale_1-25 scale_1-50 scale_1_100 This is the first part of the macro which creates the scale_1-10 dimensional style: ^C^C_dimclrd;1; dimltype;continuous; _dimlwd;-1; _dimdle;1.25; _dimdli;1.25; _dimclre;1; _dimltex1;continuous; _dimltex2;continuous; _dimlwe;-1; _dimexe;1.25; _dimexo;1.25; _dimblk;oblique; _dimldrblk;oblique; _dimasz;2.5; _dimcen;0; -style;isocp;isocp.shx;a;;;0;;;;; _dimtxsty;isocp; _Dimclrt;2; _dimtfill;0; _dimtxt;1.8; _dimtad;1; _dimgap;1; _dimtoh;off; _dimtih;off; _dimtmove;0; _dimscale;10; _dimdec;0; _dimzin;0; _dimtolj;0; _dimse1;off; _dimse2;off; _dimrnd;5; _dimtofl;on; -dimstyle;s;SCALE_1-10; The other part of the macro creates the other dimensional styles and is just placed after this part. If I use this macro/button and 1 of these styles is in use, and the command is creating him again, the following text is visible in my text window: Current dimension style: SCHAAL_1-25 Annotative: No Current dimension overrides: DIMSCALE 10.0000 Enter a dimension style option [ANnotative/Save/Restore/STatus/Variables/Apply/?] : s Enter name for new dimension style or [?]: SCHAAL_1-10 That name is already in use, redefine it? : Enter name for new dimension style or [?]: The command ends at this point. I do not have all the dimensional styles that I want to have. How can I change my macro string to solve this problem? Thank you for your advice. This is the whole macro string: ^C^C_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;oblique;_dimldrblk;oblique;_dimasz;2.5;_dimcen;0;-style;isocp;isocp.shx;a;;;0;;;;;_dimtxsty;isocp;_Dimclrt;2;_dimtfill;0;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;10;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;SCHAAL_1-10; _dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;oblique;_dimldrblk;oblique;_dimasz;2.5;_dimcen;0;-style;isocp;isocp.shx;a;;;0;;;;;_dimtxsty;isocp;_Dimclrt;2;_dimtfill;0;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;20;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;SCHAAL_1-20; _dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;oblique;_dimldrblk;oblique;_dimasz;2.5;_dimcen;0;-style;isocp;isocp.shx;a;;;0;;;;;_dimtxsty;isocp;_Dimclrt;2;_dimtfill;0;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;100;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;SCHAAL_1-100; _dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;oblique;_dimldrblk;oblique;_dimasz;2.5;_dimcen;0;-style;isocp;isocp.shx;a;;;0;;;;;_dimtxsty;isocp;_Dimclrt;2;_dimtfill;0;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;25;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;SCHAAL_1-25; _dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;oblique;_dimldrblk;oblique;_dimasz;2.5;_dimcen;0;-style;isocp;isocp.shx;a;;;0;;;;;_dimtxsty;isocp;_Dimclrt;2;_dimtfill;0;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;50;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;SCHAAL_1-50; Edited March 25, 2015 by Sandervp Reply SLW210: Please read the Code Posting Guidelines and edit your post to include the Macros in Code Tags. Quote
Dadgad Posted March 24, 2015 Posted March 24, 2015 Welcome to CADTutor. Might you consider adding these dimension styles into your .dwt TEMPLATE of choice? Any which you need will be there, any you don't will be purged later, if not used? There are guidelines on the forum for how to post executables, it would be appreciated if you follow those guidelines. Quote
SLW210 Posted March 24, 2015 Posted March 24, 2015 Please read the Code Posting Guidelines and edit your post to include the Macros in Code Tags. Quote
JGA Posted March 25, 2015 Posted March 25, 2015 How about putting the dimension styles in a separate block & just insert it into your drawing by macro? Quote
rkmcswain Posted March 25, 2015 Posted March 25, 2015 How about putting the dimension styles in a separate block & just insert it into your drawing by macro? Agreed. OP, unless you need to alter the creation parameters at run-time, just create them somewhere once and insert as needed by inserting the drawing, DesignCenter, etc. Quote
tombu Posted March 26, 2015 Posted March 26, 2015 Templates and Design Center are the key to having them available. I'd also suggest replacing dimension styles for all those scales with one annotative one you could use in any scaled viewport or even paper space. It sure made my life simpler when they added that years ago. Quote
BIGAL Posted March 27, 2015 Posted March 27, 2015 If you convert your macro to a lisp then 1st step is check if it exists if not then run. Quote
tombu Posted March 27, 2015 Posted March 27, 2015 If you convert your macro to a lisp then 1st step is check if it exists if not then run. Example: (tblsearch "dimstyle" "SCHAAL_1-10") will returns that entry. If no entry is found, tblsearch returns nil. Use it as a test and modify the dimstyle if true, add it otherwise. Quote
