Select all or convert *X### Anonymous blocks.
I need a way to select all the *X anonymous blocks (Hatches) and either convert to regular blocks, back into a hatch or just delete them.
QSelect will only do it one at a time, wildcard doesn't seem to work, Filter doesn't appear to recognize anonymous blocks, either.
I have a lot to do, one at a time , while not impossible for one drawing, I have several .dwg I would like to do.
Thanks in advance.
Here is a drawing with one *X in it.
Anonymous Hatch.dwg
Here's some quick code to select all blocks in the active layout/viewport with block names starting "*X":
(defun c:myblksel nil
   (sssetfirst nil
       (ssget "_X"
           (list
              '(0 . "INSERT")
              '(2 . "`*X*")
               (if (= 1 (getvar 'cvport))
                   (cons 410 (getvar 'ctab))
                  '(410 . "Model")
The code could of course be modified to convert/explode/delete if necessary.
Lee
Thanks!!
Works a treat, I was surprised Filter didn't handle these.
Would have been nice to convert them, but I just mainly wanted them gone and they aren't really necessary for my current work.
Once again, I appreciate this.
Thanks in advance.
Try to use U2B or U2BM command from here (download bgtools2.32.zip from #1)
M2U - Convert MINSERT to Unnamed block
M2B - Convert MINSERT to block
U2B - Convert UNNAMED to block
U2BM - Convert UNNAMED to block multiple selection
UX - Explode UNNAMED block
