IlikeCAD Posted March 27, 2015 Share Posted March 27, 2015 Good evening all, I have been drawing a 3D part and I needed a how right through it in a previous session. I draw a circle on a face extruded it through the part and subtracted the cylinder that I made to create a hole through the part. The issue is is that I have made the whole in the wrong place. I tried drawing a circle over the hole but when I try and select it all the geometry is treated as one. You can probably tell that I am clueless when it comes to AutoCAD I am just trying to practice as I have the software. Many thanks for any help that any one can give. All the best Steve Quote Link to comment Share on other sites More sharing options...
nestly Posted March 27, 2015 Share Posted March 27, 2015 Try CTRL+Click on the face you want to move (the inside of the hole) This is know as SUBOBJECTSELECTION and with a few exceptions, you should be able to move or delete the subobject pretty much as you can other objects. also SOLIDEDIT > FACE > Move Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 28, 2015 Share Posted March 28, 2015 And if you have trouble with the Move Face command you could always just fill in the hole you made with a cylinder and union the two then create a new hole. Not as efficient but doable. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 28, 2015 Share Posted March 28, 2015 And if you have trouble with the Move Face command you could always just fill in the hole you made with a cylinder and union the two then create a new hole. Not as efficient but doable. CTRL+Click then Erase/Delete also fills in the hole. Quote Link to comment Share on other sites More sharing options...
IlikeCAD Posted March 28, 2015 Author Share Posted March 28, 2015 Try CTRL+Click on the face you want to move (the inside of the hole) This is know as SUBOBJECTSELECTION and with a few exceptions, you should be able to move or delete the subobject pretty much as you can other objects.also SOLIDEDIT > FACE > Move Hi nestly, Thank you very much for your msg. I tried what you suggested and now I have one hole in the right place but the circle that I had originally drawn remains. I now have another problem I will post details in a fresh post. Many thanks Steve Quote Link to comment Share on other sites More sharing options...
IlikeCAD Posted March 28, 2015 Author Share Posted March 28, 2015 Hi ReMark, Thank you for your msg. What you say is a good idea I think I will try that in a practise drawing. Many thanks Steve Quote Link to comment Share on other sites More sharing options...
