Inserting multiple blocks w/ a coordinates list.
There is a chance the error may be related to the format of the .txt file I tried to use. I'll update when confirmed.
  • Replies 92
  • Lee Mac
    38
  • wannabe
    26
  • wizman
    8
  • ScribbleJ
    8
Definitely a problem with the .txt file. I have tried everything, but only on list of coordinates works. Ive even tried to replicate the structure of that file but to no avail.
Ok, I have some good news.
Basically, to make the coordinates text file readable to the lisp they need to be saved as an rtf in word and then saved as a plain text .txt file format, with a comma separating the coordinates.
As for the automatic identification entry, it just asks me to manually type in the information to populate this attribute for the block. Which is a slight problem in the fact I don't know which order they are inserted.
Any help appreciated.
A little hint to make things more simple, would be to open your coordinate file in Excel, then you can save as a CSV file format, and commas are inserted automatically between the coordinates and the file is in a format that can be read in Lisp. :)
The way my posted LISP works is that it reads alternate coords and attributes., then assuming the attribute is prompted for, it will submit the attirbute value.
(defun c:ITREE (/ *error* file file1 blk blkfile pts)
   (defun *error* (msg)
   (setvar "cmdecho" 1)
   (if (= msg "")
       (princ (strcat (itoa blk) " Blocks Inserted."))
       (princ (strcat "\n" (strcase msg)))
   ) ;_  end if
   ) ;_  end defun
   (selfile)
   (blocksel)
   (setvar "cmdecho" 0)
   (setq file1    (open file "r")
     blk    0
   ) ;_  end setq
   (while
   (or
       (/= (setq pts (read-line file1)) nil) ; [color=Red]READING COORDINATE[/color]
       (/= (setq atrib (read-line file1)) nil) ; [color=Red]READING ATTRIBUTE[/color]
   ) ;_  end or
      (command "-insert" blkfile pts "1" "1" "0" atrib) ; [color=Red]PASTING ATTRIBUTE TO COMMAND LINE[/color]
      (setq blk (1+ blk))
   ) ;_  end while
   (*error* "")
   (close file1)
) ;_  end defun
(defun selfile ()
   (setq file (getfiled "Select a Text File"
            "C:\\"
            "txt"
            8
          ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
(defun blocksel    ()
   (setq
   blkfile    (getfiled "Select a Block"
             "C:\\"
             "dwg"
             8
       ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
What is it that is not working?
Is it not getting to the coordinated point, or is it not inserting the block with the correct attribute, or what? :cry:
I'm assuming its something to do with the attribute, seeing as you could get the block inserted without the addition of the attribute codeing.
When I tried to insert the block, it needed the attribute, then it needed the attribute to be verified. So the attribute must be entered twice :( or the attribute should be edited so that it doesn't need verification.
what is the value of your attreq?
One note for inserting blocks with attributes in a lisp routine, you must ensure your attreq system variable is set to 1
Excellent point Wizman, I did not know of that variable - thanks for pointing that out.
Here is an updated LISP, including setting the attreq to 1:
(defun c:ITREE (/ *error* file file1 blk blkfile pts atrib)
   (mapcar 'setvar varlist oldvars)
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   (setq varlist (list "CMDECHO" "ATTREQ")
     oldvars (mapcar 'getvar varlist)
   ) ;_  end setq
   (selfile)
   (blocksel)
   (setvar "CMDECHO" 0)
   (setvar "ATTREQ" 1)
     blk    0
   ) ;_  end setq
   (while
   (or
       (/= (setq pts (read-line file1)) nil) ; READING COORDINATE
       (/= (setq atrib (read-line file1)) nil) ; READING ATTRIBUTE
   ) ;_  end or
      (command "-insert" blkfile pts "1" "1" "0" atrib) ; PASTING ATTRIBUTE TO COMMAND LINE
      (setq blk (1+ blk))
   ) ;_  end while
   (*error* "")
   (close file1)
) ;_  end defun
(defun selfile ()
            "C:\\"
            "txt"
            8
          ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
(defun blocksel    ()
   (setq
             "C:\\"
             "dwg"
             8
       ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
Have you tried to insert wannabe's block manually? It needs an extra return at the end, because the attribute needs verification.
Thanks for the comments and effort. Learnt a few new things and got myself a really handy LISP.
I can chat up the receptionist all day when I should be manually inserting blocks and changing the attributes.
:D
P.S I better check it at work before I get too carried away.
LISP is good for something then... :P :D
I see what you mean Eldon, Wannabe's Block has a double prompt for attribs - may need to double the LISP input:
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   ) ;_  end setq
   (selfile)
   (blocksel)
   (setvar "ATTREQ" 1)
     blk    0
   ) ;_  end setq
   (while
   (or
   ) ;_  end or
      (command "-insert" blkfile pts "1" "1" "0" atrib atrib) ; PASTING ATTRIBUTE TO COMMAND LINE
      (setq blk (1+ blk))
   ) ;_  end while
   (*error* "")
   (close file1)
) ;_  end defun
(defun selfile ()
            "C:\\"
            "txt"
            8
          ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
(defun blocksel    ()
   (setq
             "C:\\"
             "dwg"
             8
       ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
please try.....:-):
(defun c:ITREE (/ *error* file1 blk blkfile pts atrib file_link)
   ) ;_  end defun
   (setq varlist (list "ATTREQ" "CMDECHO" "OSMODE")
   ) ;_  end setq
   (selfile)
   (blocksel)
   (setvar "ATTREQ" 1)
   (setvar "OSMODE" 0)
  blk	0
   ) ;_  end setq
   (while
(and
    (setq file_link (read-line file1))
    (setq atrib	(vl-princ-to-string
		    (car (read (strcat "(" file_link ")")))
		) ;_ end_VL-PRINC-TO-STRING
    ) ;_ end_setq
    (setq pts (read (strcat "(" (read-line file1) ")")))
) ;_  end or
   (command "-insert" blkfile pts "1" "1" "0" atrib ATRIB)
   (setq blk (1+ blk))
   ) ;_  end while
   (close file1)
   (*error* "")
) ;_  end defun
(defun selfile ()
		 "C:\\"
		 "txt"
		 8
       ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
(defun blocksel	()
   (setq
		  "C:\\"
		  "dwg"
		  8
	) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
The last routine gives the error: "NO FUNCTION DEFINITION: BLOCKSEL" as soon as the text file is selected.
EDIT: The last routine from Lee.
What format will the text file need to be in Wizzman? I.e, where will I need to place the text that will be used to populate the attribute?
By default it comes out as attribute,coordx,coordy.
same as posted samppy.txt, i had a quick ran at it, too tight sched right now, try to come back later
