Inserting multiple blocks w/ a coordinates list.
The Attribute Editor does not appear for me...
lee/wannabe
if it does appear during an insertion of a block with attribute while running your lisp, set attdia to 0 to remove the editor.....:-)
How do you know so many variables.... :P
  • Replies 92
  • Lee Mac
    38
  • wannabe
    26
  • wizman
    8
  • ScribbleJ
    8
Superb, Lee.
Now I can get back to what I come to work for and not have to insert blocks and spend my time on CAD ( chatting up the receptionist :D )
also, during insertion of a block using insert command, your osnaps may give wrong coordinates.
either;
(command "-insert" blkfile "_non" pts "1" "1" "0")
or set osmode to 0
Good point Wizman,
I think by the end of this, the routine will be close to perfect with the amount of refinements we've had! :)
I have added Wizman's suggestion, and improved the way the routine sets the variables. - its untested my end, so *hopefully* it'll work!
(defun c:ITREE (/ *error* file file1 blk blkfile pts atrib blkent)
   (defun *error* (msg)
   (mapcar 'setvar varlist oldvars)
   (if (= msg "")
       (princ (strcat (itoa blk) " Blocks Inserted."))
       (princ (strcat "\n" (strcase msg)))
   ) ;_  end if
   ) ;_  end defun
   (setq varlist (list "CMDECHO" "ATTREQ" "OSMODE")
     oldvars (mapcar 'getvar varlist)
   ) ;_  end setq
   (selcfile)
   (blocksel)
   (mapcar 'setvar varlist (list 0 0 0))
   (setq file1    (open file "r")
     blk    0
   ) ;_  end setq
   (while
   (and
       (/= (setq pts (read-line file1)) nil)
       (/= (setq atrib (read-line file1)) nil)
   ) ;_  end and
      (command "-insert" blkfile pts "1" "1" "0")
      (setq blkent (entget (entnext (entlast))))
      (setq blkent (subst (cons 1 atrib) (assoc 1 blkent) blkent))
      (entmod blkent)
      (setq blk (1+ blk))
   ) ;_  end while
   (command "_regenall")
   (*error* "")
   (close file1)
) ;_  end defun
(defun selcfile    ()
   (setq file (getfiled "Select a Co-ordinate File"
            "C:\\" ; [b][color=Red]Change this to change default Search path[/color][/b]
            "txt"
            8
          ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
(defun blocksel    ()
   (setq
   blkfile    (getfiled "Select a Block"
             "dwg"
             8
       ) ;_  end getfiled
   ) ;_  end setq
) ;_  end defun
Now you can get back to chatting up the receptionist...
Ahh, and one more thing - bear in mind that you can change the parts that I have highlighted in red to suit your filepath so that you won't need so many clicks! - Even more time converted to chat-up time!
Just remember to use double backslash, and also finish on a double backslash,
i.e.
C:\\Lee Mac\\Folder\\
i.e.
LOL
Cheers.
  • 4 years later...
Mr. Lee,
Your lisp seems to be perfect to me.
I'm looking for it in ages.
Do you mind if ask for a little request for your code?
your lisp didn't working for my text format.
FUNCTION CANCELLED
Can you help me, please?
TEST.txt
BTREE.dwg
Thank in advance
  • 2 weeks later...
Hi Dear Lee Mac,
Would you please help me to solve my problem?
Indeed I need a lisp routin that can insert a block atomate in to any intersections i have in my drawing.
Thanks in advance for your kindness.
Sincerely Yours,
Javid.:)
Edited by javid
Wrong request:">
  • 8 months later...
I hope you guys are still there... I have same problem. Trying to insert a block at particular coordinates and put a text adjacent. I have created a .txt file - with these sample :
12090,968118.4815',202777.4346'
12063,968118.5594',202360.2748'
12033,968118.7333',201601.7047'
12044,968118.7707',201736.1973'
12038,968118.8927',201647.7227'
when I put in lisp routine - I get pop up asking for location of txt file then pop up for block location. All that works o.k. - but then I get:
BAD ARGUMENT TYPE: LENTITYP NIL
I am sure it is something I am missing - remember, I am not fluent in lisp routines...
(if (= msg "")
) ;_ end if
) ;_ end defun
(setq varlist (list "CMDECHO" "ATTREQ")
) ;_ end setq
(selcfile)
(blocksel)
(setvar "CMDECHO" 0)
(setvar "ATTREQ" 0)
blk 0
) ;_ end setq
(while
(and
) ;_ end and
(entmod blkent)
(setq blk (1+ blk))
) ;_ end while
(*error* "")
(close file1)
) ;_ end defun
(defun selcfile ()
"C:\\Users\\Wbode\\Documents\\c.txt\\"
"txt"
8
) ;_ end getfiled
) ;_ end setq
) ;_ end defun
(defun blocksel ()
(setq
"C:\\Users\\Wbode\\Documents\\donut.dwg\\"
"dwg"
8
) ;_ end getfiled
) ;_ end setq
) ;_ end defun
Wow - this is an old thread! :oops:
@WBODE: First off - welcome to CADTutor!
My code in this thread is incredibly old and very poorly written by my current programming standards; as a quick workaround, you could try my (also rather old) Point Manager program, with the input set to 'File' and output set to 'Block'.
I hope this helps!
PS: Please edit your post and enclose your code with code tags:
[highlight][noparse]
[/noparse][/highlight] Your code here [highlight][noparse]
I will see if our IT group will let me download... thank you.
