Guitte Posted April 1, 2015 Posted April 1, 2015 Good day, Is there away on ACad LT, that can tell you what the length of an ellipse is? What we need to do is take a half ellipse and divide it in equal length segments along the ellipse line. Any advice on this, will be appreciated. Guitte Quote
Guitte Posted April 1, 2015 Author Posted April 1, 2015 Hi Steven-g, Thank you!! We divided the halve ellipse in 3 and use the 3 point arc command. We calculate each arc's length, there is our answer. Jippy! Quote
eldon Posted April 1, 2015 Posted April 1, 2015 Do you have the command Lengthen? if so, then start the command and click on your half ellipse. The current length is displayed. Quote
steven-g Posted April 1, 2015 Posted April 1, 2015 I figured it was the dividing part that was more of interest, but if you really need the length, you could also look at setting pellipse=1 and redraw the ellipe, which will draw your ellipse as a polyline. Quote
Guitte Posted April 1, 2015 Author Posted April 1, 2015 I figured it was the dividing part that was more of interest, but if you really need the length, you could also look at setting pellipse=1 and redraw the ellipe, which will draw your ellipse as a polyline. Will put it in my note book, Steven-g. Dont know much about ellipses. Quote
Guitte Posted April 1, 2015 Author Posted April 1, 2015 Hi eldon, No i don't know where to get the command "Lengthen" in ACad LT. Quote
Guitte Posted April 1, 2015 Author Posted April 1, 2015 100% Eldon, it also works. Thanks, that one also going to the note book. Quote
