running auto cad 15.
the layout tabs at the bottom of the screen. I will click on the first lay out tab to work in it, so i look up into model space. then when i look back down at the layout tabs, it has moved to the last tab. If i'm working in a middle layout tab, the look down and it has moved to the last tab. guessing my question is. Why / how are the layout tabs moving without me manually moving the tab. by manual i mean if i want to move a tab i press down left mouse and drag and drop...
Here is a good location with that exact issue. If you look through you will find a "hotfix" that should fix the issue.
