I am using autocad 15 (student)
In before when i select some object and make copy or move command my selected object remain selected but suddenly that changed. now if i select something before make any command that selected object gone unselected.
and the key delete is not working.
how can i solve this problem?
Thank you.
Make sure the system variable PICKADD is set to a value of 1. While you are at it make sure PICKFIRST is also set to 1.
There is a thing called noun/verb verb/noun you will find the settings also via CONFIG Selection Z_y_nayon you may want to have a look at few of the other tabs.
Delete key not working yes I get this now and again use E for erase then it works. 2013.
Thank you for your help @ReMarK. :)
Thanks BIGAL.
