Hello.
I'm pulling my hair out trying figure out how to use associative lists.
My goal is to create a function that would populate a global list. It need to accept a name for assoc and value that it will append to it.
For example an existing list:
("blah1" (1 2 3 5)
"blah2" (4 3 2 1)
I'd like to add (4 6 7) to "blah1" list and (1 5) to "blah2" also add another list as "blah3" with values (3 4 5)
So the end result would be:
("blah1" (1 2 3 5 [color=red]4 6 7[/color])
"blah2" (4 3 2 1 [color=red]1 5[/color])
"blah3" ([color=red]3 4 5[/color])
In javascript this is done ridiculously simple:
var myList = {
   blah1: [1, 2, 3, 5],
 blah2: [4, 3, 2, 1]
function addToList (key val)
   myList[key].push(val);
addToList("blah1", [4, 6, 7]);
addToList("blah2", [1,5]);
addToList("blah3", [3, 4, 5]);
Can someone please help.
Thank you.
Are you wanting to be prompted for the new/additional list values or are there any other source for the those?
No, no prompts, other part of the script will supply them, I need a function that would populate the list with supplied values
(defun addTListDemo  (addvalues existinglist)
     (foreach
            value  addvalues
           (Setq existinglist
                      (if (setq AddorNew
                                     (assoc (car value)
                                            existinglist))
                            (subst (list (car AddorNew)
                                         (append (cadr AddorNew)
                                                 (cadr value)))
                                   AddorNew
                                   existinglist)
                            (append existinglist (list value))
     existinglist
(setq lst '(( "BLAH1" (1 2 3 5))("BLAH2" (4 3 2 1))))
( addtlistdemo '(("BLAH1" (4 6 7))("BLAH2" (1 5))("BLAH3" (3 4 5))) lst)
(("BLAH1" (1 2 3 5 [b][color="blue"]4 6 7[/color][/b])) ("BLAH2" (4 3 2 1 [b][color="blue"]1 5[/color][/b])) [b][color="blue"]("BLAH3" (3 4 5))[/color][/b])
INDIVIDUAL
(defun addTListDemoi  (addvalue existinglist)
     (if (setq AddorNew (assoc (car addvalue) existinglist))
                      (append (cadr AddorNew)(cadr addvalue)))
                      AddorNew existinglist)
         	(append existinglist (list addvalue))
(addtlistdemoi '[b][color="blue"]("BLAH2" (1 5))[/color][/b] lst)
(("BLAH1" (1 2 3 5)) ("BLAH2" (4 3 2 1[b][color="blue"] 1 5[/color][/b])))
(addtlistdemoi '[b][color="blue"]("BLAH3" (3 4 5))[/color][/b] lst)
(("BLAH1" (1 2 3 5)) ("BLAH2" (4 3 2 1)) [b][color="blue"]("BLAH3" (3 4 5))[/color][/b])
OFF TOPIC @kaan27: exceeded quota for PM / Who is Original Author/ Cant see the image on the link / What does it do / Why not post the request on the board?
Edited by pBe
Thank you very much! The second example is exactly what I was looking for.
Good for you vanowm and you are welcome. hope you'll learn from the demo code.
Cheers :)
