pBe Posted April 6, 2015 Share Posted April 6, 2015 Jeez AIberto , you have to make up your mind. , with that dialog another set of questions will be gong your way. [mostly from me ] Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 6, 2015 Author Share Posted April 6, 2015 Jeez AIberto , you have to make up your mind. , with that dialog another set of questions will be gong your way. [mostly from me ] ,,, Hi pBe , I don't know, can you understand? can you help me? Quote Link to comment Share on other sites More sharing options...
pBe Posted April 6, 2015 Share Posted April 6, 2015 But I am helping you. but please refrain from changing your requirements on every post you make. Believe me, modifying someone else's code is no walk in the park, specially DCL and Lisp codes of this kind. And add to that, an ever changing requirement. Now having said that. please be very clear from this post onward. I will look into this later. And hopefully the conditions will be all set / frozen / locked / no more addition / final / This is what i want / This is it really / The sky is blue..... ] And also, be patient pBe AND also , i saw you post the same request at another forum. Makes me think twice about modifying the code now Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 6, 2015 Author Share Posted April 6, 2015 But I am helping you. but please refrain from changing your requirements on every post you make. Believe me, modifying someone else's code is no walk in the park, specially DCL and Lisp codes of this kind. And add to that, an ever changing requirement. Now having said that. please be very clear from this post onward. I will look into this later. And hopefully the conditions will be all set / frozen / locked / no more addition / final / This is what i want / This is it really / The sky is blue..... ] And also, be patient pBe Hi pBe. I'm very glad to have your help. Now, the request should be very clear ? Quote Link to comment Share on other sites More sharing options...
pBe Posted April 6, 2015 Share Posted April 6, 2015 Hi pBe.I'm very glad to have your help. Now, the request should be very clear ? AND also , i saw you post the same request at another forum. Makes me think twice about modifying the code now Listen, if by tomorrow no one else jumps in to help you here or at TheSwamp, then i will work on modifying the code. Cheers pBe Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 6, 2015 Author Share Posted April 6, 2015 Listen, if by tomorrow no one else jumps in to help you here or at TheSwamp, then i will work on modifying the code. Cheers pBe Ok! I will wait for your good news . ,Thanks very much! Quote Link to comment Share on other sites More sharing options...
pBe Posted April 7, 2015 Share Posted April 7, 2015 There is something very odd running the original program. Can you verify if its doing the same thing on your end 1. Modify button doesn't do anything 2. Add/Del button at Library panel goes haywire after a while. The program should not accept duplicates but somehow it does Deleting duplicates add more strings 3. Up and Down button adds more string to the list. EDIT: Found the problem Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 There is something very odd running the original program. Can you verify if its doing the same thing on your end 1. Modify button doesn't do anything 2. Add/Del button at Library panel goes haywire after a while. The program should not accept duplicates but somehow it does Deleting duplicates add more strings 3. Up and Down button adds more string to the list. EDIT: Found the problem Hello pBe. But tests found no problem on my side. Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 Hi pBe Sorry. I have found a BUG Quote Link to comment Share on other sites More sharing options...
pBe Posted April 7, 2015 Share Posted April 7, 2015 That's odd. Did you try to add a new string? say "banana" click add twice then try and delete the duplicates? Also notice there are duplicates on the list shown on your gif attachment? Hi pBeSorry. I have found a BUG EXACTLY! and no worries, i found the bug and fixed it. Hang in there. it almost done Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 Hi pBe. Sorry for that. Can you fix this BUG ? Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 EXACTLY! and no worries, i found the bug and fixed it. Hang in there. it almost done You are great ! Quote Link to comment Share on other sites More sharing options...
pBe Posted April 7, 2015 Share Posted April 7, 2015 (edited) Wait for it....... HYG ;;; START | New function to switch from one list to another ;;; (defun repstringlist ( sname / clst) (setq crtlstS (subst (list curkey crtlst) (Assoc curkey crtlstS) crtlstS)) (setq crtlst (cadr (Assoc sname crtlstS))) (setq curkey sname) (do_list "itemlist") (updlst "itemlist" crtlst) ) ;;; END | New function to switch from one list to another ;;; ;;; This is where add Additional INI files, there are currently ;;; ;;; 3 spare names as shown on the Dialog box, You can add more ;;; ;;; As needed. ;;; ;;; Reminder: ;;; ;;; tcf.DCL file should also be edited for additional ;;; ;;; ini files & name change ;;; (or crtlstS (setq ini_list '([b][color="blue"]"spare3" "spare2" "spare1" "cast" "sheet" "mech" "tcf"[/color][/b]) crtlstS (readfn ini_list))) ;;; ;;; The rest of the code are modified to accommodate multiple string list ;;; START | Edited to [b][color="blue"]READ only once [/color][/b]per drawing session ;;; ..... ;;; START | Edited to[b][color="blue"] WRITE only once [/color][/b]per command invoke & end ;;; .... Cheers pBe Modified.#4... tcfv1.1.LSP Modified.#2...tcf.dcl INI files ................ Ini Files.rar Edited April 9, 2015 by pBe Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 Wait for it....... HYG [ATTACH=CONFIG]53663[/ATTACH] Cheers pBe Hi pBe. Thanks very much! Only strings in the list can be inserted into the drawing . So, I want insert the machine's technical requirements in the drawing, need one by one add to the list . This is not quickly. I think need a " Add all" button. Do you think? Quote Link to comment Share on other sites More sharing options...
pBe Posted April 7, 2015 Share Posted April 7, 2015 (edited) Hi pBe.Thanks very much! You are welcome AIberto. Dont forget to give credit to the original author [ cabinsummer ] Only strings in the list can be inserted into the drawing . So, I want insert the machine's technical requirements in the drawing, need one by one add to the list . .... This is not quickly. I think need a " Add all" button. Do you think?[ I know its not, ASAICT that is the way the original code works. What did i say about changing the requirements AIberto? I think that part is easy [or maybe not ] BUT, this will be the last one, no more additional request / no more change this to that / no more i think need a ___ / Roses are red, violets are blue / Po-tay-to po-tah-to.... Now if you an tell me how to get 4 gallons of water using a 3 and a 5 gallon jug, [ that one is easy ] then maybe i'll modify the code. EDIT: show the solution using math equation Edited April 7, 2015 by pBe Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 You are welcome AIberto. Dont forget to give credit to the original author [ cabinsummer ] I know its not, ASAICT that is the way the original code works. What did i say about changing the requirements AIberto? I think that part is easy [or maybe not ] BUT, this will be the last one, no more additional request / no more change this to that / no more i think need a ___ / Roses are red, violets are blue / Po-tay-to po-tah-to.... Now if you an tell me how to get 4 gallons of water using a 3 and a 5 gallon jug, [ that one is easy ] then maybe i'll modify the code. EDIT: show the solution using math equation oh. you test my english ,no,no,no, my english is so bad. Quote Link to comment Share on other sites More sharing options...
pBe Posted April 7, 2015 Share Posted April 7, 2015 oh. you test my english ,no,no,no, my english is so bad. Isn't that fun AIberto That's one way of doing it. good enough Check the code at post#33 for updated LSP and DCL file Cheers pBe Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 7, 2015 Author Share Posted April 7, 2015 Isn't that fun AIberto That's one way of doing it. good enough Check the code at post#33 for updated LSP and DCL file Cheers pBe Thank you.sincerely . I have seen that your modified. but I found a BUG, Can you verify if its doing the same thing on your end when I choose the commonly used is "Machining parts", and add a new string "mech string 8" ,use "Down" button moving "mech string 8" to the last. Then, change the commonly used to "Sheet Metal parts" What has happened ? The dialog exit and display error. Quote Link to comment Share on other sites More sharing options...
pBe Posted April 7, 2015 Share Posted April 7, 2015 (edited) Hang on. i'll have a look-see ..... still not happening on my end.. testing....... Wait for it...... [pause | stepping out for Dinner ].. " I'll be back" BUG squashed I need you to find more bugs to squash If i've known its going to be like this , I would have written the code from scratch. CODE UPATED post#33 Edited April 7, 2015 by pBe Quote Link to comment Share on other sites More sharing options...
AIberto Posted April 8, 2015 Author Share Posted April 8, 2015 Hang on. i'll have a look-see ..... still not happening on my end.. testing....... Wait for it...... [pause | stepping out for Dinner ].. " I'll be back" BUG squashed Thank you. You are very enthusiastic and friendly. If i've known its going to be like this , I would have written the code from scratch. CODE UPATED post#33 I'm so sorry. the original program have many shortcomings. If can placed Strings dynamically, that will be perfect. I need you to find more bugs to squash I'dont know,Is this a BUG Quote Link to comment Share on other sites More sharing options...
