Multileaders not keeping up with changes in model space
Hi
The multileader shows up to scale in the viewport. But when i change the position of the multileader or change the width of the text box these ammendments do not show up in viewport?:(
Katie
Different annotation scales for model space and viewport?
Thanks. I am now editing inside the vport instead and working so far.
Okay, as long as you are satisfied with not finding out why it doesn't work in model space.
Each annotative object will only respond to those simple type moves or edits in the current scale, if that scale is assigned to the object. Complete moves will show up in all scales. It is how they work. Make your adjustments through an active viewport, as you have discovered, OR change the annotative scale in modelspace. There should be a pop up list for that, similar to the one on the taskbar for viewport scaling. 2010 does have that, right? That way, the fitment can be adjusted for the crowding that occurs at smaller scales without it affecting the appearance in other scales. 1:20 is more crowded up than 1:10, for instance.
do a regenall in paperspace, sometimes AutoCAD Doesn't update the view correctly when switching spaces, and a regenall should solve that. depending on how many layouts and or viewports it can take a couple of seconds to perform. and save before you run the command, I have had heavy drawings crash when performing this command
