Import Excel file into MS DataGrid with AutoCAD debug using C sharp.
I am using C sharp.
Import excel file into MS DataGrid with AutoCAD debug I get the following
Error Messages.
MS Jet OLEDB.4 provider in not register on local machine
Application does not support JIT debugging.
I have a program using the following statements
private string Excel03ConString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source={0};Extended Properties='Excel 8.0;HDR={1}'";
private string Excel07ConString = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source={0};Extended Properties='Excel 8.0;HDR={1}'";
The program is used to import an excel file to a data grid.
The program works as an independent program but when I copy and paste my code into
a program that uses AutoCAD debug I get the following messages.
Why is this happing when I use AutoCAD debug?
Thank you,
if AutoCAD is running as 64-bit then you need a 64 bit Jet Engine. Oh, the bad news - I don't think there is one. You could try http://epplus.codeplex.com/ for working with Excel.
Is there another way to import an excel file to a C# data grid not using
Microsoft.Jet.OLEDB.4.0 Or Microsoft.ACE.OLEDB.12.0?
Thank you,
