Editing Hole text in Inventor 9
After editing the hole text ..... the text disappear , problem similiar to previous after installing the Hotfix from window update K918118.
Previous problem with Window update K918118 solve but now problem happen again. Any patch or which update from Microsoft that causes this problem .
Using Inventor 9
ALL SP install
Hi
I am using Inventor 9 , when ever I edit the "hole note" add some remarks to the text . the whole dimension and text will disappear.
This problem happen before when Window update K918118 automatically install to the PC. This problem solve with some patch file from Autodesk.
Recently the problem appear again ...... and there is no patch from Autodesk.
Any update from Microsoft causes this problem.
Please help.
I moved this thread to the dedicated forum. I hope you will receive an answer soon.
thank you and please let me know which forum
I have merged your two threads into this one. Your question is in the Inventor forum. Scroll down to the "Other Autodesk Products" section and look for the "Autodesk Inventor" forum.
When in doubt, look at the menu bar at the top of the page. It will tell you where you are.
