Create Perpendicular Line at every intersection point
  • Replies 69
  • Lee Mac
    27
  • CAB
    14
  • SEANT
    13
  • priyanka_mehta
    7
Posted Images
Your routine is fine Lee.
I just wondered why you were going to all the trouble thats all. :)
Just enjoying the exercize.:)
Most of the subroutines I just pulled from my other routines.
The main routine & getClosestPointTo I had to create.
I know what you mean, the fun is in creating the routine, not necessarily running it. :P
Yes, I'll never use half of the routines I write.
As I was just telling David Bethel - the only two LISPs I ever have loaded on my machine are these:
(defun c:enn () (entnext (car (entsel))))
(defun c:en ()    (entget (car (entsel))))
And, they themselves are only for reference. :P
Writing the LISPs is the best part. :thumbsup:
I feel likewise – that the fun is in the challenge. 8)
So, in an effort to let VBA share some of the challenge, see attached. It is somewhat of a Frankenstein, with a mix and match of parts from earlier routines, but it seems to run well enough. It should find all vectors perpendicular to a selected LWPolyline from the intersections of a selection set of line entities.
Warning: Extremely limited testing and error checking!
Intersect2PolyPerp.txt
I imagine he would be (though that may not be the case if the routine happens to break catastrophically). :shock:
I also imagine that the contributors to CADTutor learn quite a bit in their effort to help others. That really seems to be the case with this particular forum.
Conceivably, it takes a lot of practice to become a good coder. As you and CAB implied; our own requirements may not offer enough coding opportunities to get really good. We owe those asking for coding examples a great deal of gratitude.:shifty:
That is a very good point. - I would not know half as much about LISP as I do now (which still probably isn't very much), if it weren't for the problems posted on this forum.
Wow,
I just looked as I haven't for a while, I have 1,394 .lsp files ( 22 mb ) in my working directory. I could probably clear out a hundred or 2.
My Acad.LSP IS 56 kb and probably has 200 so files quick loads.
I have 1 customer that all I do 1 day a week is write code for. The rest are for my companies internal use. Go figure.... -David
Wow,
Blimey David - I only have about 200 lisps :)
Wow,
Damn! Isn’t it amazing that as capable as AutoCAD already is, the use of it is so varied as to require an additional 1394 capabilities.
I wonder how many of those 1394 LISPs AutoDesk have now incorporated into AutoCAD over the years...
Any coincidence that IEEE 1394 is the standard designation for a FireWire connection? Yeah...its probably a coincidence. Although you never know...perhaps I have a financial interest in the relevence of the 1394 connection requiring me to mention it whenever possible...
(I do not)
(I do not)
Haha you are so random Maxwell - just like your avatar.
Seant,
Probably half of the routines are parametric routines that builds food service equipment. There a lot of editing things that Acad has incorporated some what over the years. For the most part they are directly specific to my needs. A lot of what Acad has now has come from user's requests or basically taken from forums like this. Express tools started out that way.
Maybe 20% belong to my customers as I write them and assign copyrights or exclusives to them. And then there some old old things I use as learning tools. -David
Thank you Lee. I like to think that while everyone walks straight ahead on the path of life, I stop at the pay phones to check for change.
(I like the new sig by the way)
I have quite a collection of files, many I barrowed. :)
And I keep several version deep when I write them.
Oops, that was all files. There are only 4,408 lsp files and there must be 20% douplication for copies of versions.
