Oljetter Posted April 16, 2015 Share Posted April 16, 2015 hello, I inherited a title block from someone else in the company and it is loaded with perhaps 20 MB of invisible content. I have done the following without success to reduce the file size: Purged many times. There are blocks which won't purge because they may be nested or for some other reason. I have deleted the dwg bit by bit to check the file size - it remained big, even with nothing visible. I have checked all the layers for any possible content - zoomed to extents and deleted everything on all layers. I believe the problem lies with blocks from previous projects nested inside the drawing which won't delete. Purging won't allow ne to delete nested or x-referenced blocks. Any other suggestions, please! Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted April 16, 2015 Share Posted April 16, 2015 (edited) Use quick select to see just what else is in the drawing (wipeouts etc) & I take it your purging with 2015 which removes DGN issues (bloated file size) Check your annotation scales, regapps etc http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/regapp-id-cleanup-utility-for-autocad-2015.html http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/scale-list-cleanup-utility-for-autocad-2015.html Wblock out is an option & if all else fails see excellent posts below. Best of luck & welcome to the forum. p.s. you can always post your dwg for people to take a look see Edited April 16, 2015 by KiLLiNG-TiME Quote Link to comment Share on other sites More sharing options...
Commandobill Posted April 16, 2015 Share Posted April 16, 2015 If you dxf your drawing, it will clear out anything that is not in use. Generally, I would do this twice with a drawing of that size. So, use the command "dxfout" save the dxf somewhere, then type "dxfin" and open the dxf you just created. Do that twice then save it as an dwg. If you purge after that the drawing will be clean as a whistle. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 16, 2015 Share Posted April 16, 2015 Start fresh and WBlock what you need. Quote Link to comment Share on other sites More sharing options...
Oljetter Posted April 16, 2015 Author Share Posted April 16, 2015 I appreciate the prompt response. All the contributions are staight forward and make me wonder why the heck I did not think of it, but we live and learn. Tomorrow is another day. I inherited a title block from someone else in the company and it is loaded with perhaps 20 MB of invisible content. I have done the following without success to reduce the file size: Purged many times. There are blocks which won't purge because they may be nested or for some other reason. I have deleted the dwg bit by bit to check the file size - it remained big, even with nothing visible. I have checked all the layers for any possible content - zoomed to extents and deleted everything on all layers. I believe the problem lies with blocks from previous projects nested inside the drawing which won't delete. Purging won't allow ne to delete nested or x-referenced blocks. Any other suggestions, please! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 16, 2015 Share Posted April 16, 2015 You might also look into the -PURGE>Regapps to Purge Regapps and -PURGE>All which will also remove Zero Length Geometry and Empty Text Objects. I don't know why post #2 assumes you have AutoCAD 2015, when your profile has AutoCAD 2013. Scale List Cleanup Utility for AutoCAD 2013/2014 AutoCAD® DGN Hotfix 2013/14 Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted April 17, 2015 Share Posted April 17, 2015 (edited) Post 2 didn't assume (but he maybe blind yes sorry i missed the 2013 got it mixed up with joined date 2015 didn't have my magnifying glasses on) but it was just my way of saying have you looked into the DGN's issue, i like people to do at least a little research themselves, i dropped the clue, hence the wink & (bloated file size). PS If your having issues with nested blocks you could try this lisp from the excellent Lee Mac. http://www.lee-mac.com/extractnestedblock.html https://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3aextractnestedblock_windows32and64%3aen Edited April 17, 2015 by KiLLiNG-TiME can't bloody spell Quote Link to comment Share on other sites More sharing options...
