lisp to set dimdec and select and update dimension
Hello everyone,
I am trying to make a lisp file that will make commands "0" through "9" to change the dimdec variable to the respective number and then ask me to select a dimension (as when I type "dim" and then "up") and update the precision accordingly.
I started with this that someone helped me on for an array for dimscale but I was not sure how to edit it since I want the numbers to be the commands themselves...
(defun c:setdimdec(/ i)
(setq i 1)
(repeat 9
(eval(read(strcat "(defun c:d" (itoa i)
"()(setvar \"DIMSCALE\" " (itoa i)
")(princ))")))
(setq i(1+ i))
); end repeat
); end of test
(c:test)[\code]
Try this:
(defun c:dd (/ *error* dim ss ssl)
   (defun *error* (msg)
   (setvar "cmdecho" 1)
   (if (= msg "")
       (princ "\nFunction Complete.")
       (princ "\nError or Esc Pressed...")
   ) ;_  end if
   ) ;_  end defun
   (setvar "cmdecho" 0)
   (if
   (>= (setq dim (getint "\nSpecify Number of Decimal Places: ")) 0)
          (setvar "DIMDEC" dim)
          (setq ss (ssget))
          (if (/= (setq ssl (sslength ss)) 0)
          (command "-dimstyle" "a" ss "")
          (alert "No Dimensions Selected.")
          ) ;_  end if
      ) ;_  end progn
      (alert "Number of Decimal Places must be Positive.")
   ) ;_  end if
   (*error* "")
   (princ (strcat "\n" (itoa ssl) " Dimensions Updated."))
) ;_  end defun
Thanks LeeMac! That works very well. Is there any way to assign the command "0" to be "dd" and then "0", "1" to be "1" and etc? This will just make it so that I have to type one less input.
An example for "0":
(defun c:[color=Red][b]0[/b][/color] (/ *error* ss ssl)
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   (setvar "DIMDEC" [b][color=Red]0[/color][/b])
   (setq ss (ssget))
   ) ;_  end if
   (*error* "")
) ;_  end defun
Change the highlighted zeros to different numbers to suit your needs.
Or, maybe this to update all dimensions in drawing all at once.
(defun c:0 (/ *error* ss ssl)
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   (setvar "DIMDEC" 0)
   (setq ss (ssget "X" (list (cons 0 "DIMENSION"))))
   (alert "No Dimensions Exist.")
   ) ;_  end if
   (*error* "")
) ;_  end defun
  • 2 weeks later...
thanks LeeMac. You rule. Have a nice day.
Cheers Noel, (Happy New Year to you also) :thumbsup:
