I love using my ordinate dimensions but in most of my work, 1/4" is far close enough for precision... it's easy to select my source coordinate and change the precision but can I set it prior? :?
Yes, that is where it is changed, but when I change it there, it changes the precision for more than just the Ordinate Dimensions. Can I change their precision by itself?
Yes you can set a different precision for your ORDINATE dimensions by starting a CHILD dimstyle.
In your dimstyle manager choose NEW, and you will be guided through creating a new dimstyle which can be specified to be used
only for ORDINATE dimensions, then set the precision however you want it on the PRIMARY tab.
Check out the last couple of posts in this thread
http://www.cadtutor.net/forum/showthread.php?92066-Radial-Dimension-Display-Circle-at-arrow-head...
Edited by Dadgad
Dadgad, thank you so much! That was a spot on answer, fast and easy. Thank you for what you do!
You are very welcome, glad I could help you. :beer:
