Helo my friends!
Its been a while since i post happy to be back.
Im loiking for a way to export my cuix to indented text list.
Ive tried to browse the xml but there where to much unneeded data. I need only the names .
Why i need it? I want to document my costumization. Doing it one by one might take me several years.
Thanks
Sami
ACad 10
1st thing make a copy of your cuix rename to .zip and open save all to a new directory. Use cui to mnu.vlx this converts the cui to a mnu in the example below Surfal.cuix the only cui I needed to convert was popmenu.cui you may need to do all as my menu was a partial to start with. I have attached the original surfal.mnu the renamed surfal.zip and then the converted popmenu.mnu so you can compare to original. You will still need to edit it a bit buts its close.
I renamed a couple by adding txt to upload. Next time will zip
surfal.mnu.txt
surfal.zip
PopMenuRoot.cui.mnu.txt
CUI to MNU.zip
