Hi guys, is there a way to remove or erase portion of polyline in shortest way by lisp, as shown at the figure attached..
  • Replies 21
  • Tharwat
    9
  • martinle
    6
  • notview
    4
  • Lee Mac
    3
Posted Images
Thank you LM. TRIM command is done well in figure at left, but figure at right will not erase, only trim portion.
Figure at right is polyline with two vertex. Is this possible to make lisp routine, if select two vertex polyline it will erase, combining to TRIM.
The figure shown above is only portion of my work, sometimes many polyline crossing each other, TRIM command alone will not solve my problem.
Thank you for your help!
Try this :
(defun c:Test  (/ s o a b c)
;;;	Tharwat 27.4.2015	;;;
 (if
   (and (setq s (entsel "\n Select a Polyline to trim segment :"))
        (wcmatch (cdr (assoc 0 (entget (setq o (car s))))) "*POLYLINE")
    (cond ((= (cdr (assoc 90 (entget o))) 2) (entdel o))
          (t
           (setq a (fix (vlax-curve-getparamatpoint  o  (vlax-curve-getclosestpointto o (cadr s))))
                 b (vlax-curve-getpointatparam o a)
                 c (vlax-curve-getpointatparam o (1+ a))
           (command "_.Break" o "_none" b "_none" c "")
It's great!! Tharwat.
It help me a lot.. Only command at a time, can you make this continue until escape and, or, select more than one then trim/erase the selected segments.
Thank you Tharwat!! It solved my problem.. hahaha..
Excellent , happy to hear that :D
No you can not use multiple selection with this task but if you wan to keep the program running until you hit enter , just replace the IF function with while .
Try not to use Escape button for any command unless you have no way to , so hit enter would avoid errors messages and exit commands safely ( in general ) .
Good luck .
Thank you to advice and to your time of this code, it save me a lot of time.
Superb! Everything is fine.
Thank you Tharwat!
Thank you Tharwat!
You are welcome anytime . :)
Hello Tharwat.
I have problems when I'm out in the BCS with this Lisp.
There it did not work. Could you gaze again what could be missing here?
Martin
Hello Tharwat.
Martin
Hi Martin , happy to see you posting again :)
Yeah, I guess the routine works only with WCS . Can you upload a sample drawing to allow me to try it out with that system ?
Hello Tharwat, unfortunately I do not know how you attach a file.
Martin
Take a look at the right side hand down of the forum and there must be a button called Go Advanced , hit the button then you should be able to find the attach button and lots of other interesting things ;)
Unfortunately I could not make it working on other than WCS , I am sorry :(
Hello Tharwat,
ok. Thank you.
If you transfer your drawing into WCS , the program should work as expected otherwise no luck with it .
The following modifications should enable UCS compatibility:
(defun c:test ( / a e s x )
   (if
       (and
           (setq s (entsel "\nSelect polyline to trim segment: "))
           (setq e (car s)
                 x (entget e)
           (= "LWPOLYLINE" (cdr (assoc 0 x)))
       (if (= 2 (cdr (assoc 90 x)))
           (entdel e)
               (setq a (fix (vlax-curve-getparamatpoint e (vlax-curve-getclosestpointto e (trans (cadr s) 1 0)))))
               (command
                   "_.break" s "_f"
                   "_non" (trans (vlax-curve-getpointatparam e a) 0 1)
                   "_non" (trans (vlax-curve-getpointatparam e (1+ a)) 0 1)
Good solution Tharwat :thumbsup:
