remizana Posted May 1, 2015 Posted May 1, 2015 Hi guys I use Autocad 2013 and I have a file which the whole of it is a minsert . when I explode it, it says: Command: x EXPLODE Select objects: Specify opposite corner: 1 found 1 was minserted. Select objects: None found. and when I list it : BLOCK REFERENCE Layer: "0" Space: Model space Handle = 4cb75f Block Name: "*U319" at point, X= 0.0000 Y= 0.0000 Z= 0.0000 X scale factor: 1.0000 Y scale factor: 1.0000 rotation angle: 0 Z scale factor: 1.0000 Scale uniformly: No Allow exploding: Yes I did flatten and no , then explode and it didn't work I saw the previous post about exploding a minsert and they didn't work too. I downloaded some Autolisps such as: BLKBUSTexplode minserts exmins and nothing happed!! finally I found this: http://www.cadstudio.cz/en/download.asp?file=ExplodeM apparently it explodes my file , but after that all drawings disappear!!! and says: Command: EXPLODEM Select MINSERT: Command: Command: EXPLODEM Select MINSERT: A single Insert detected - explode? [No/Yes] : Y Exploded MINSERT replaced by 2 blocks (can be exploded now) lockdwg: : when it says lockdwg: : the drawings have been vanished already and I don't know what should I write or to do in front of lockdwg: : please let me know, If anyone knows the solution BLKBUSTexplode minserts.LSP Quote
rkent Posted May 1, 2015 Posted May 1, 2015 A minsert is made with a block so ignore the minsert and type Insert and look at the names available, one of them is the whole drawing. Erase the minsert and insert that block and then explode it. Quote
