Guitte Posted May 8, 2015 Share Posted May 8, 2015 Hi, Is it possible to copy paperspace tabs into a new drawing, without using "Save as" as an option? Kind Regards, Guitte Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 8, 2015 Share Posted May 8, 2015 No, but you can import layouts. My images came in out of order. Right click on the layout tab or preview window and select "From Template". Make sure file type is set to .dwg. Browse to file and open it. Select the layouts that you want and click on OK.. Quote Link to comment Share on other sites More sharing options...
eyde Posted May 8, 2015 Share Posted May 8, 2015 Yes you can. Go to one of your tabs in the new drawing (not the model tab) right click and select (from template) then browse to find the drawing that you want import your tabs from and select the tabs you want. That's all there is to it. Quote Link to comment Share on other sites More sharing options...
Guitte Posted May 8, 2015 Author Share Posted May 8, 2015 Thanks RobDraw, your awesome! Sit for almost an hour figuring, searching and trying. Thanks once more. Quote Link to comment Share on other sites More sharing options...
