SOLVED (06/02/2015):
Hello,
I am looking to move a block and it's surrounding objects all to origin with reference to the block insertion point.
When the move command prompts me to "Select a base point," can I somehow choose the insertion point of a block?
Thanks,
Losinski
EDIT 05/12/2015:
I'm sorry, I was in a rush when I posted this and should have been more specific.
I'm (hopefully) going to make a script that will select and move all, with reference to a blocks insertion point, to 0,0. I need to know if this is possible solely through commands.
BIGAL: Yes, this is for three different kinds of titleblocks (NP ISO A0, NP ISO A1, NP ISO A2). I currently have three different scripts, but if they could all be combined into a lsp that would be even better. Ultimately it would need to:
Change to paper space (either "Layout" or "Layout1").
Determine which block is being used.
Select all in paper space.
Move all, with reference to the determined block's insertion point, to 0,0.
Delete all outside of the border.
The window coordinates for each of the block borders are as follows:
NP ISO A0: (-10,10) and (1179,-831)
NP ISO A1: (-10,10) and (584,-410)
NP ISO A2: (-10,10) and (831,-584)
Thanks,
Losinski
Edited by Losinski
Original issue resolved.
Hi Losinski,
The answer is yes. You'll need to make sure that you have the 'INSERT' osnap turned on, or use SHIFT+RIGHT CLICK to bring up the temporary osnap overrides.
Is this a lot of title blocks on layout tabs ? let me know I have a fix. Just run a lsp
Thanks,
Losinski
Is the block the only thing in the paperspace?
If no, is the block in a unique layer?
If you can answer yes to either of these then you can select the block in a script, then set the UCS to that object, move the previous selection from 0,0, switch the UCS back to World before entering the destination coordinates of 0,0.
Something like (no testing done yet, just a concept script):
-Layer
Lock
Unlock
Titleblock
SelAll
Move
0,0
0,0
-Layer
Unlock
UCS
Object
Previous
Move
Previous
0,0
'ucs
WORLD
0,0
here is an example based on a title block
; moves all objects in pspace to 0,0 alignment
; by BIG AL May 2015
(defun c:ABT ( / len plottablist oldnsap ed k ss n xy p1 p2)
(PROMPT ".....now moving dwgs....")
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Layouts doc)
 (setq plotabs (cons (vla-get-name lay) plotabs))
(setq plottablist (acad_strlsort plotabs))
(setq len (length plottablist))
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(setq K 0)
(repeat len
 (setq name (nth K plottablist))
 (princ name)
 (if (/= name "Model")
   (setvar "ctab" name)
   (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 "NP ISO A1,NP ISO A2,NP ISO A3") ) ))
(if (> (setq n (sslength ss)) 1)
(alert "you have more than 1 title block")
   (setq en (ssname ss 0))
   (setq xy (assoc 10 (entget en)))
   (setq x (cadr xy))
   (setq y (caddr xy))
   (setq bname (cdr (assoc 2 (entget en)))) ; needed cdr
(cond
((= bname "NP ISO A0")(setq L 1184)(setq w 841)) ;redone to suit OP
((= bname "NP ISO A1")(setq L  841)(setq w 594))
((= bname "NP ISO A2")(setq L  594)(setq W 420))
; rework out  erase window need offsets from title block A1 841x594
(setq p1 (list (setq p1x (- x 10))(setq p1y (- (- Y 10) w))))
(setq p2 (list (setq p2x (+ 10 (+ x L)))(setq p2y (+ 10 Y))))
(vl-cmdf "erase" "all" "remove" "W" P1 P2 "")  ; needed ""
   (command "move" "w" p1 p2 "" (list x y) "0,0")
   (command "zoom" "E")
   ) ;end progn
) ; end if
) ; end repeat
(setvar "osmode" oldsnap)
Edited by BIGAL
version 2
Thank you for your replies.
YZ:
The won't be the only thing in paper space. I will need to delete the items that reside outside of the title block border. The block is on a layer called SHEET, along with a couple other blocks that make up the finer details of the overall title block.
BIGAL:
Your lisp worked very well. However, I still require a few more functions built in.
Ideally:
The title block selection becomes automatic- would have to choose between three different blocks: "NP ISO A0," "NP ISO A1," AND "NP ISO A2."
The items that are outside of the title block window after the move will be deleted.
The items that reside outside of the following windows, based on block, would have to be deleted:
Note: Only ONE of these blocks will be present at a time.
The following is an example of a simple script for deleting all items outside of the NP ISO A1 block (I tried to wrap CODE tags around the text and they didn't show up).
erase
all
remove
window
-10,10
831,-584
Also, I know very little about lisp routines. To run the one you posted I used the appload command and had to load it each time I wished to use it. Is it the "defun" line that adds a name to the lisp? I would like to run the routine by the command name "ADJUSTTITLEBLOCK" or "ATB" for short.
Thanks again,
Losinski
1 I changed the post to now be a defun you need to Autoload it or add to your appload HIstory so its always there. Search autoload if not sure.
2 I would erase outside first then move much easier as if objects overlap will not work.
3 Will see if I can find time to make it a (cond and look for your block names auto you can add more then etc. It will require making the code into a couple of defuns for simplicity.
Okay, thank you BIGAL. That sounds good.
I have updated the first code posted and removed from here.
Just a suggestion make your title block insert point lower left much easier to work out everything.
Edited by BIGAL
Loaded the lisp and got this error:
"Command: ; error: malformed string on input"
Thanks for the time you've put in thus far.
I Think BIGAL may have left for the day... try this...
(defun c:ABT ( / len plottablist oldnsap ed k ss n xy minxy maxxy)
(setvar "osmode" 0)
(setq K 0)
(repeat len
 (princ name)
   (setq bname (assoc 2 (entget en)))
 ; insertion pt   (setq xy (assoc 10 el))
   (setq xy (list (cadr xy)(caddr xy)))
(cond
((= bname "NP ISO A1")(setq p1 "-10,10")(setq P2 "831,-584"))
((= bname "NP ISO A2")(setq p1 "-10,10")(setq P2 "584,410")) ; < missing "
((= bname "NP ISO A3")(setq p1 "-10,10")(setq P2 "410,298"))
(vl-cmdf "erase" "all" "remove" "W" P1 P2)
   (command "move" "w" p1 p2 "" xy "0,0")
   ) ;end progn
) ; end if
(setq K (+ K 1))
(princ k)
(setq ss nil)
(setq xy nil)
) ; end repeat
That lisp loaded correctly Spaj.
When run, the drawing zoomed to extents and stopped there. The following is what appeared in the command window.
__________________________________________________________________
Command: ABT
.....now moving dwgs....Layout1Application ERROR: Invalid type sent as command
input
move
Select objects: w
Specify first corner:
Command:
Command: ABT Unknown command "ABT". Press F1 for help.
Command:
Command: 0,0 Unknown command "0,0". Press F1 for help.
Command: zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : E
Command: 1Layout1Application ERROR: Invalid type sent as command input
move
Select objects: w
Command:
Command:
Command: zoom
Command: 2Layout1Application ERROR: Invalid type sent as command input
move
Select objects: w
Command:
Command:
Command: zoom
Command: 3Model4Model5Model62199
Thanks Spaj as I said not tested its much easier if we have a sample dwg to test on.
Its firday here so will see what I can do over week end.
I've attached a test drawing containing a version of the NP ISO A1 block. I can attach one for the NP ISO A2 and NP ISO A0 if need be.
Thanks again,
Losinski
TEST DWG.dwg
Great work. The lisp does exactly what I needed, however it doesn't work for NP ISO A0.
This is the error:
".....now moving dwgs....Layout1; error: bad argument type: lselsetp nil"
Thanks,
Losinski
  • 2 weeks later...
I had a closer look at the program for general typos and found NP ISO A3 instead of NP ISO A0. Changed it in the program and it worked like a charm for all blocks.
Thanks again BIGAL for all of your work put into this.
