Loaded a PDF image into 2011 version----is there a simple way to change it to autocad use?????
No there isn't. You will need to find a PDF to DWG conversion program. Test a handful out because some are notoriously bad at what they do.
This topic has been discussed many times in the past so either look at the Similar Threads list below or search on conversion programs.
It it VERY dependent on HOW the PDF file was created.
Was it a paper drawing scanned to a PDF? In that case, the PDF is simply a wrapper for a TIF file. Raster to Vector is a very inexact science and likely to result in a mess.
Was it printed to PDF from a CAD program like AutoCAD or Microstation? If so, then a lot depends on the PDF driver, but you may have a fairly good vector PDF that can be converted back to CAD with decent results.
If you're unsure of the origin or if the PDF contains a mixture of vector and raster, then you're somewhere in between the two extremes above.
I've used this with good results in the past (on Vector PDFs!): http://www.dotsoft.com/pdf2dwg.htm
You've also got several online (nothing to install) programs such as: http://dwg.autodwg.com/ and http://www.cometdocs.com/ that you can explore.
Edited by rkmcswain
add more links
Agreed, Adobe PDF drivers has produced a better result than say CutePDF printer in my tests in converting back to dwg.
