Bodies not accepting "Normal Cut" option in extrude cut
I have a sheet metal part that I am trying to get a flattened pattern for. As the part stands now it will flatten, but it isn't completed yet. After you roll forward you will see that there is a sketch profile for the material that I want left after the outside material is cut. After the cut is made though, it does not allow me to flatten the part. I think the reason for that is because I don't have "Normal cut" selected, but with this part, normal cut does not work. I don't know how to fix this part so that I can normal cut and then flatten it. Let me know if you are able to figure out a solution.
I am using Solidworks 2015 with the newest service pack.
Thank you
Example.SLDPRT
