A few weeks ago I was given some useful code for reading data from a file off a website.
What I want to know is if it is also possible to write to a file on a website?
Here is the code that retrieves the data from file:
(defun c:wtw ()
(setq server "http://example.com.au/Folder/")
(setq SetSunFile "testpost.txt")
(setq SundayFilepath (strcat server SetSunFile))
(setq xmlSunday (vlax-create-object "MSXML2.XMLHTTP.3.0"))
(vlax-invoke-method xmlSunday 'open "POST" SundayFilepath :vlax-false)
(vlax-invoke-method xmlSunday 'send)
(setq strSunday (vlax-get-property xmlSunday 'responsetext))
abd here is what I tried to add to write to file....whichc doesn't work.
(vlax-put-property SundayFilepath 'Write testwr)
thanks
Edited by Andrew1979
FYI This code was for your protection routine so dont post true website address, remove strcat etc not needed (strcat "testpostSunday.txt")
Have a look at this link its not lisp but does talk about writing a txt file to a server https://msdn.microsoft.com/en-us/library/ms766431(v=vs.85).aspx
something like
(vlax-put-property xmlSunday 'write testwr)
