kizaerf Posted May 19, 2015 Posted May 19, 2015 Ever since I put the titleblock xref in a new folder, the drawing where I xreffed it in, doesn't seem to 'remember' the new location. The old path location be under 'saved path' and I will change the 'found at' to update it. But every time I reopen the drawing, it reverts back to the old and won't update the 'saved path' and I need to do it manually every time. Please help. This is autocad 2012 Quote
BlackBox Posted May 19, 2015 Posted May 19, 2015 Sounds like you have this block in two locations, and the previous location is higher in your Support File Search Paths (SFSP)... Meaning it is 'found' first. Either remove/rename the block in the previous location (so there is only one to find), or edit your SFSP accordingly. Cheers Quote
