BIGAL Posted May 23, 2015 Posted May 23, 2015 (edited) So many times I see multiple questions in a lisp and thought that a nice dcl would be better but writing DCL and interface LSP is time consuming, so I am trying to combine the two basicly by just loading a seperate lisp and a couple lines of code you can have from 1 line input to as many as DCL supports. Anyway its so close so I have posted here the code it auto makes the dcl and the required lsp to run it. I just have a bit of a writers block and its so close. So to anyone out there appreciate a look. ;; writes a multiline input dcl file from generic input ;; By BIG AL May 2015 (defun AH:write-items (keynum title / ) (write-line ": edit_box {" f1) (write-line (strcat " key = " (chr 34) Keynum (chr 34) ";") f1) (write-line (strcat " label = " (chr 34) title (chr 34) ";" ) f1) ; these can be replaced with shorter value etc (write-line " edit_width = 18;" f1) (write-line " edit_limit = 15;" f1) (write-line " is_enabled = true;" f1) (write-line " }" f1) (if (= AHnum nil)(setq AHnum 0)) (write-line (strcat "(action_tile " (chr 34) keynum (chr 34) " " (chr 34) "(setq item" (rtos (setq AHnum (+ AHnum 1)) 2 0) " $value)" (chr 34) ")" ) f2) ) ; this defun writes the first few lines of the lsp and dcl files (defun AH:openfiles () (setq f1 (open "C://acadtemp//getval.dcl" "w")) (setq f2 (open "C://acadtemp//getvals2.lsp" "w")) ; dcl (write-line "ddgetval : dialog {" f1) (write-line (strcat "label = " (chr 34) "Enter values" (chr 34) ";") f1) (write-line ": column {" f1) ;lsp (write-line (strcat "(setq dcl_id (load_dialog " (chr 34) "c:\\acadtemp\\getval" (chr 34) "))" ) f2) (write-line (strcat "(if (not (new_dialog " (chr 34) "ddgetval" (chr 34) " dcl_id))" ) f2) (write-line "(exit))" f2) ) ; defun ; closes files ;dcl (defun AH:closefiles () (write-line "spacer_1 ;" f1) (write-line "ok_cancel;}" f1) (write-line "}" f1) (close f1) ;lsp (write-line "(START_DIALOG)" f2) (write-line "(done_dialog)" f2) (close f2) (setq num nil) ) ; this is test code which would be added to a seperate routine asking 4 questions (AH:openfiles) (AH:write-items "key1" "Title1") ; (setq ans1 key1) (AH:write-items "key2" "Title2") ; (setq var1 key2) (AH:write-items "key3" "Title3") ; (setq var2 key3) (AH:write-items "key4" "Title4") ; (setq xx key4) (AH:closefiles) ;(load "C:\\acadtemp\\getvals2") ; it should return 4 values item1 item2 item3 item4 ;(alert (strcat item1 "\n" item2 \n item3 \n item4)) ; just a test line Edited May 25, 2015 by BIGAL Quote
BIGAL Posted May 25, 2015 Author Posted May 25, 2015 Code updated above The end result a DCl with as few or as many lines as required rather than writing or editing multiple dcl's Quote
