dweafer Posted May 27, 2015 Posted May 27, 2015 (defun C:hatchAREA (/ a ss n du) (setq a 0 du (getvar "dimunit") ss (ssget '((0 . "*HATCH")))) (if ss (progn (setq n (1- (sslength ss))) (while (>= n 0) (command "_.area" "_o" (ssname ss n)) (setq a (+ a (getvar "area")) n (1- n))) (alert (strcat "The total area of the selected\nobject(s) is " (if (or (= du 3)(= du 4)(= du 6)) ; ;The following 2 lines translate the area to square inches and feet ;for users using US engineering or architectural units: ; (strcat (rtos a 2 2) " square inches,\nor " (rtos (/ a 144.0) 2 3) " square feet.") ; ;In the following line, change the word "units" to whatever units ;you are using - meters, millimeters, feet, etc. ; (strcat (rtos a 2 3) " square units."))))) (alert "\nNo Polylines selected!")) (princ) ) (alert (strcat "POLYAREA.LSP (c) 1997-2001 Tee Square Graphics" "\n\n Type POLYAREA to start")) (princ) Hi is there any one that might be able to help me change the code from a lisp from TEE Sqaure Graphics. this code puts an AutoCAD alert on the screen, Is there any way the alert can be changed to a multileader A thanks in advance if anyone can help Quote
