LASSAADTH Posted June 2, 2015 Posted June 2, 2015 I programmme a lisp in autocad, I want to insert a point with coordinates {(X + 10), (X + 100)} in my drawing I have a text in the form: X: 50.00m what is the function that allows me to just get (extract) the value 50.00 by selecting text in AutoCAD. I want to use this value in certain functions. Thank you for your aid. Quote
GP_ Posted June 2, 2015 Posted June 2, 2015 One... (defun str->num (strin / num) (distof (vl-list->string (vl-remove-if-not '(lambda (x) (or (= x 46) (<= 48 x 57))) (vl-string->list strin) ) ) ) ) (str->num "X: 50.00m") 50.0 _1$ Quote
LASSAADTH Posted June 2, 2015 Author Posted June 2, 2015 I try both solutions proposed but without success I send you my lsp file: step: 1- get a real PC (the one I want to select the text directly in my file) 2-select the Horizontal and Verticla axis and draw the intersection point 3-choose my points and have the texts with. ********** (defun c:POI (/ P1 x1 y1 D1 Z1 PC ss PO pt P2 x2 y2 D2 Z2) (setq PC (getreal "\nPC\n")) I want to get this value with selecting text in dwg file?? (setq Angle (getvar "AUNITS")) (setvar "AUNITS" 2 ) (if (and (setq ss (ssget '((0 . "LINE,LWPOLYLINE")))) (= 2 (sslength ss)) (setq int (vLa-intersectwith (vLax-ename->vLa-Object (ssname ss 0)) (vLax-ename->vLa-Object (ssname ss 1)) acextendnone ) ) (setq PO (vLax-safearray->List (vLax-variant-vaLue int))) ) (repeat (/ (length PO) 3) (setq pt (list (car PO) (cadr PO) (caddr PO))) (command "_.POINT" pt) ) ) (while ; SELECTION A (setq P1 (getpoint "\Point A: ")) (setq x1 (rtos (- (car P1) (car PO)) 2 2)) (setq y1 (rtos (+ (- (cadr P1) (cadr PO)) PC) 2 3)) (setq D1 (strcat x1)) (setq Z1 (strcat y1)) (command "_MTEXT" P1 "H" 0.34 "L" 20 D1 "") (command "_MTEXT" P1 "R" 100 "H" 0.34 "L" 20 Z1 "") ; SELECTION B (setq P2 (getpoint "\Point B: ")) (setq x2 (rtos (- (car P2) (car PO)) 2 2)) (setq y2 (rtos (+ (- (cadr P2) (cadr PO)) PC) 2 3)) (setq D2 (strcat x2)) (setq Z2 (strcat y2)) (command "_MTEXT" P2 "H" 0.34 "L" 20 D2 "") (command "_MTEXT" P2 "R" 100 "H" 0.34 "L" 20 Z2 "") ) ) *************** Thank you for helping me. Quote
BIGAL Posted June 3, 2015 Posted June 3, 2015 I use lee's parse numbers no problems works great (setq test "test string 123") (car (LM:parsenumbers test)) ; answer is returned as a list with one value ;returns 123 Quote
BIGAL Posted June 9, 2015 Posted June 9, 2015 You must copy Lee's Parse into your code ; did TEXT asdf 123 hjk (setq obj (vlax-ename->vla-object (car (entsel)))) ; picked the text (setq txtstr (vla-get-textstring obj)) (car (LM:parsenumbers txtstr)) ; answer is returned as a list with one value ;returns 123 Quote
